STD Other FS / WTB / Buying guides 16v Dogleg transmission
EmJay
09-30-2013, 11:54 AM #1
Not mine, but figured someone here would appreciate it:
http://forum.190rev.net/showthread.php?4...sion/page2
Location is in Oregon
EmJay
Druk
09-30-2013, 04:23 PM #2
I couldn't access the link so cant see the advert but remember this trannie has it's own dedicated shifter. A standard merc box shifter wont work.
Druk
EmJay
10-01-2013, 01:04 AM #3
It sold.....
EmJay
It sold.....
CRD4x4
CompoundSuperTurboDiesel4x4!
399
10-01-2013, 05:12 PM #4
I know its sold but;
Is this MB 16v dogleg the same as a BMW M3 dogleg?
The BMW dogleg transmission is a Getrag 265/5 (265/6 OD).
Just wondering...Huh
'05 Jeep Liberty CRD - 160k
'06.5 VW Jetta TDI - 230k
CRD4x4
10-01-2013, 06:17 PM #5
I think the dogleg in the 16v merc is from the cosworth 190 IIRC..
My friend HughF on this forum fitted one to his OM606 compound powered 190..
Druk
10-02-2013, 03:54 AM #6
^ Yup! I've got one behind a 606.962. Bolts straight on.
As I said above it needs it's own matching turret. The levers work differently from the standard 5speed turret.
This post was last modified: 10-02-2013, 03:56 AM by Druk.
Druk
CRD4x4
399
10-02-2013, 09:22 AM #7
Does the Cosworth 190 dogleg 5-speed have a removable bellhousing or is it a 1-piece case?
CRD4x4
Druk
10-02-2013, 11:20 AM #8
One piece case.
Druk
One piece case.
10-02-2013, 01:47 PM #9
(10-01-2013, 05:12 PM)CRD4x4 I know its sold but;
Yep, same thing, but with a different engine bolt pattern. Good stuff if you don't mind a 1:1 top gear.
EmJay
10-04-2013, 04:40 PM #10
I got one in my 190 cosworth, it sure helps that little car fly. If something happens to the 16v motor, I'm going to drop a 602 under the hood and have some torquey fun
EmJay
 6 Guest(s)
 6 Guest(s)
