STD Other Non MBZ Diesel SD-22 Nissan compact truck diesel
08-13-2009, 08:10 AM #1
Late 80s body, early 80s nissan SD-22 diesel swap. Never before have I seen such a great concept with excellent parts so poorly executed.
This post was last modified: 08-13-2009, 08:12 AM by JB3.
08-13-2009, 04:39 PM #2
Doesn't look to god awful to me. I jsut saw one of these engines up close last weekend.
08-14-2009, 07:49 AM #3
The engine is straight in there. The conversion was otherwise completely hacked. The engine actually needed to come out and be rebuilt and the motor mounts more accurately welded. The wiring was also a major problem.
Beautiful little truck though, once its redone right, probably be great.
Pretty heavy duty little engine right? Almost the same design concept as the mercedes engines, but with everything on the opposite side.
This post was last modified: 08-14-2009, 07:50 AM by JB3.
08-14-2009, 01:03 PM #4
I alwaysi thought a Jeep Comanche 2wd with a 617 turbo and 4spd wound be sweet!
SurfRodder
Jackass Extraordinaire
611
08-15-2009, 01:14 AM #5
(08-14-2009, 01:03 PM)willbhere4u I alwaysi thought a Jeep Comanche 2wd with a 617 turbo and 4spd wound be sweet!
since those had the jeep inline six, the 617 would def fit...
OBK# 62
SurfRodder
OBK# 62
08-15-2009, 02:20 AM #6
(08-15-2009, 01:14 AM)SurfRodder since those had the jeep inline six, the 617 would def fit...
And weigh almost the same.
tantank79
T3-45
109
08-15-2009, 09:13 AM #7
http://www.dieselbombers.com/diesel-engi...om617.html
-Brian
1983 300TD
1982 240D
1981 280TE
tantank79
-Brian
1983 300TD
1982 240D
1981 280TE
SurfRodder
611
08-15-2009, 09:35 AM #8
(08-15-2009, 02:20 AM)ForcedInduction And weigh almost the same.
yeah, both cast iron block/head and roughly the same dimensions... If I didnt already have a BUILT motor in my XJ, I would totally swap it out for a 617, just so it could burn oil as well.
OBK# 62
SurfRodder
OBK# 62
