STD Tuning Drivetrain flexi disc alternative
mantahead
10-01-2013, 03:57 PM #1
hi,
using 330d gearbox and supra backend, both have 3 bolt flanges designed for rubber flexi disc.
would like to do away with them and use bolt on drive shaft with hardy spicer in each end. whats my options?
mantahead
hi,
Duncansport
10-08-2013, 11:23 AM #2
(10-01-2013, 03:57 PM)mantahead hi,
Your a smart guy with a lathe correct? Turn those flanges down and fit a weld on u-joint end and have a drive shaft made up. Fairly easy stuff here in the states...i would think you have plenty of drive shaft shops your was as well?
Duncansport
mxfrank
10-09-2013, 06:41 AM #3
If you have a 617, you could use one of these adapters and install a t5 or tremec. Use a Dana 44 rear.
http://www.mercedesdiesel4x4.com/category_s/1831.htm
1987 Mercedes 190TD
mxfrank
1987 Mercedes 190TD
mantahead
10-10-2013, 05:58 PM #4
(10-08-2013, 11:23 AM)Duncansport
i've no lathe unfortunately, was thinking of getting alloy flanges made and go for shaft with u-joints.
not alot of driveshaft shops over here.
This post was last modified: 10-10-2013, 05:59 PM by mantahead.
mantahead
giezy
12-01-2013, 01:21 AM #5
(10-09-2013, 06:41 AM)mxfrank
use a t5 from a ford and a 8.8 center dif from a t-bird/lincon and get a posie with pleanty off gear ratio's
giezy
mxfrank
12-02-2013, 01:54 PM #6
I don't know specifically what flanges are avaliable for this application. But the way to figure it out is to remove the existing flanges, and measure the shaft splines.You need to know the major diameter and the spline count. A quick check of the Dana/Spicer catalog would tell you if there are any viable options:
http://www2.dana.com/pdf/J300-P4.pdf
1987 Mercedes 190TD
mxfrank
1987 Mercedes 190TD
Druk
12-02-2013, 06:19 PM #7
(10-10-2013, 05:58 PM)mantahead i've no lathe unfortunately, was thinking of getting alloy flanges made and go for shaft with u-joints.
That's the route I took. Works very well. The steel disc in pic #1 is for the speedo pick-up.
[Image: propshaft032_zps32f02000.jpg]
[Image: propshaft031_zps396cf3f4.jpg]
This post was last modified: 12-02-2013, 06:20 PM by Druk.
Druk
mantahead
12-03-2013, 05:23 PM #8
looks good and strong.
i'm waiting on my alloy flanges to be finished. Then i will sort out a shaft.
mantahead
SurfRodder
Jackass Extraordinaire
611
12-11-2013, 08:35 PM #9
here's what I did...
http://www.superturbodiesel.com/std/Thre...5#pid58525
OBK# 62
SurfRodder
OBK# 62
