STD Tuning Engine OM 648 TURBO RETROFIT
MB TECH
08-18-2009, 08:28 AM #1
I am currently in the process of installing a turbo from an OM648 engine onto the 300TD, with this I also am using an intercooler from a 2004 C class kompressor (front mount about 3ft long), I have the intercooler mounted and am looking for some ideas for the ducting to the turbo and intake obviously using the shortest amount of piping. Not sure if anyone out there has utilized a front mount of this configuration but I am open to any suggestions.
1979 450SEL 6.9 - stock
1960 220SE
2005 S55 AMG - stock
2006 SLK55 AMG - stock
MB TECH
1960 220SE
08-18-2009, 11:21 AM #2
Holes can be drilled into the fenderwell metal if you can't get the tubes to go up the side of the engine.
MB TECH
08-18-2009, 12:05 PM #3
Ya thats what I was thinking about doing, of course since mine is a former Wisconsin car I can just push a hole through the inner fenders (NO DRILLING REQD ON RUST HAHAHA)
1960 220SE
MB TECH
1960 220SE
08-18-2009, 12:53 PM #4
ah its been lightened good start to a race car!!! lol the glass is half full
MB TECH
08-18-2009, 01:09 PM #5
(08-18-2009, 12:53 PM)willbhere4u ah its been lightened good start to a race car!!! lol the glass is half full
My thoughts exactly!
1960 220SE
MB TECH
1960 220SE
benztek
MASTER TECH
61
08-18-2009, 04:04 PM #6
Make sure you check that turbo. The few 648 turbos that I have warrantied have had alot of shaft play.
benztek
08-18-2009, 04:22 PM #7
(08-18-2009, 01:09 PM)MB TECH
It's got natural speed holes!
MB TECH
08-18-2009, 04:54 PM #8
(08-18-2009, 04:04 PM)benztek Make sure you check that turbo. The few 648 turbos that I have warrantied have had alot of shaft play.
I did check this one and it is in excellent condition virtually no play, It has 120K on it and just the electronic actuator took a dump. Thanks for the heads up.
1960 220SE
MB TECH
1960 220SE
benztek
MASTER TECH
61
08-20-2009, 10:08 AM #9
I have replaced several for the same reason. I just have not been able to convice myself to do the fabrication work to mount one up if it has any play in the shaft.
benztek
MB TECH
08-20-2009, 12:07 PM #10
Ya I wouldnt either if this one had play, The fab work is a little more than what I wanted to do but its been slow at the shop so it keeps me busy.
1960 220SE
MB TECH
1960 220SE
08-20-2009, 08:13 PM #11
keep us updated and take some pic! What kind of boost numbers do you plan on pushing?
MB TECH
08-21-2009, 11:51 AM #12
I have been taking plenty of pics, not sure of the boost pressure, im looking more for a more efficient turbo and adding the intercooler for lower intake temps. I drive the car from Mississippi to Wisconsin alot and im trying to push a little more economy. Plus my factory turbo was starting to sound like it was coming apart.
1960 220SE
MB TECH
1960 220SE
MB TECH
08-25-2009, 07:26 AM #13
Here are some pics of the 648 turbo to 617 project. Will have more pics soon.
1960 220SE
MB TECH
1960 220SE
tantank79
T3-45
109
08-25-2009, 07:44 AM #14
What is that intercooler from?
-Brian
1983 300TD
1982 240D
1981 280TE
tantank79
-Brian
1983 300TD
1982 240D
1981 280TE
MB TECH
08-25-2009, 07:55 AM #15
early 2000 c230 sport (203 chassis with 271 engine)
1960 220SE
MB TECH
1960 220SE
tomnik
08-25-2009, 08:12 AM #16
This looks like the same turbo that I have installed in my SD. Should be a GT23. Pics in the VTG installation thread.
Tom
This post was last modified: 08-25-2009, 08:31 AM by tomnik.
tomnik
Tom
08-25-2009, 09:39 AM #17
Looks like a GT2256V. Can you confirm? If it is do you want to make another adapter for me? pm price if it is a gt2556v.
MB TECH
08-25-2009, 10:07 AM #18
I will check when I get home tonight
1960 220SE
MB TECH
1960 220SE
08-25-2009, 09:58 PM #19
(08-25-2009, 09:39 AM)winmutt Looks like a GT2256V.
Its a 2359, the compressor housing is right.
MB TECH
08-26-2009, 08:08 AM #20
That is correct it is a 2359
1960 220SE
MB TECH
1960 220SE
MB TECH
08-31-2009, 12:42 PM #21
Almost finished with the project, have a question though. Anyone who has installed a different turbo on their 617, what type of configurations did you use for the oil return line?
1960 220SE
MB TECH
1960 220SE
08-31-2009, 08:36 PM #22
I cut off the flare and o-ring parts of the return tubes and pressed a 3/4" low-pressure hydraulic hose between them.
MB TECH
09-01-2009, 06:48 AM #23
great thanks, I will try something similar.
1960 220SE
MB TECH
1960 220SE
tomnik
09-01-2009, 08:46 AM #24
I made it with a flex SS piece. Important for me was that I put a small tube into the original drain tube and another larger one as kind of cap in touch with the o-ring of the drain tube.
tomnik
MB TECH
09-03-2009, 01:56 PM #25
Ended up using steel braided line for feed and return, I started it up last night and so far no leaks. We will see how it holds up.
1960 220SE
MB TECH
1960 220SE
09-03-2009, 07:18 PM #26
looks good keep us up to date! like the blue paint I did mine red! but it peeled off as it was only good 2 500deg I need to re do it with some 1000deg paint
09-04-2009, 08:49 AM #27
Can I have your electronic actuator?
Tymbrymi
Klatta Klatta
185
09-04-2009, 10:32 AM #28
(09-04-2009, 08:49 AM)winmutt Can I have your electronic actuator?
He said the actuator took a dump, which is why he got the turbo. I need to find one of those since I have an actuator off of my GT2056 Angel
edit: Looks good MB Tech!!! Keep up the good work! I may have to try and come down this weekend and partake in some shenanigans. Wink
This post was last modified: 09-04-2009, 10:34 AM by Tymbrymi.
John Robbins
Tymbrymi
John Robbins
MB TECH
09-05-2009, 06:15 AM #29
Ya that is correct, the actuator did take a dump, I took it upon myself to look into why it failed and I found that inside are a series of plastic type material gears and one of them just stripped out (not sure exactly why it did that, I was thinking maybe excessive heat that the gears cannot take.) either way this was about 4 months ago and I did throw the pieces out. If I come across another I will let you know.
1960 220SE
MB TECH
1960 220SE
Tymbrymi
Klatta Klatta
185
09-05-2009, 01:40 PM #30
(09-05-2009, 06:15 AM)MB TECH ...either way this was about 4 months ago and I did throw the pieces out. If I come across another I will let you know.
If you would be so kind as to be on the lookout for another GT23 with bad actuator that would be much appreciated!! Angel
John Robbins
Tymbrymi
John Robbins
MB TECH
09-09-2009, 07:56 PM #31
Got it running! Still have a few things to get finished including a painted valve cover that I just finished. But it runs great I have been driving it since Monday afternoon and the response is incredible and EGTs are staying down. Also the engine temp is under control with the new 1600cfm aux fan.
1960 220SE
MB TECH
1960 220SE
09-09-2009, 08:42 PM #32
wow that's quite the hood!!! cool front mount inter cooler!
MB TECH
09-10-2009, 07:47 PM #33
thanks, the hood was a result of a few beers and a rivet gun, I think it turned out good.
1960 220SE
MB TECH
1960 220SE
larryratcliff
09-13-2009, 01:20 PM #34
How many psi of boost do you expect from this upgrade. I have been contemplating how the vw 2.0 is able to produce such amazing hp and torque numbers and it seems that the biggest part of the equation is boost.
My second question is how to match a mechanical pump to additional boost levels. I am still a bit of diesel noob but it sure seems that mechanical pump issues from gas burners would apply to diesels too. Can you send off a mechanical pump and have it re-calibrated for additional boost levels?
It looks to me that if the 3.0 mercedes was running around 1 bar it would be a serious beast since it looks like the stock boost is about 1/3 of that.
larryratcliff
09-13-2009, 08:18 PM #35
well a diesel runs cooler the leaner it get so adding boost won't hurt it as much as adding fuel!
the real power to be had is by adding fuel! but to keep EGT's under control you need to add more air (boost) to keep it nice and cool!
MB TECH
09-14-2009, 05:49 AM #36
That is true, I have not determined the max boost of this turbo since my piping blew off around 25psi, So I have been keeping it around 10psi max. See the entire reason for this upgrade for me was a more efficient setup with better response (not more power) I use this car as a daily driver and I run it on many long road trips so I am trying to squeeze some more fuel economy out of it and run a bit cooler. I am sure if I did the (removing of the rack limiter modification) I would gain quite a bit more power but right now that is not the goal. Maybe in the future, so for now the 123 wagon just looks fast hahaha
1960 220SE
MB TECH
1960 220SE
benztek
MASTER TECH
61
09-14-2009, 12:21 PM #37
How did you connect to that intercooler? That one has the click in style hoses correct? I have that same intercooler but I havent come across a solution yet.
benztek
MB TECH
09-14-2009, 12:42 PM #38
All I did was order silicone adapters large enough to stretch over the quick connect area to the smooth part and tightened them down with t bolt clamps. No leaks yet and going on week #2 of driving it back and forth to work.
1960 220SE
MB TECH
1960 220SE
benztek
MASTER TECH
61
09-14-2009, 01:16 PM #39
Thanks. I had thought about doing that but cutting off the quick disconnect area. Glad to see it up and running. What kind of control are you using for the vanes?
benztek
MB TECH
09-14-2009, 02:49 PM #40
as of right now a zip tie holding it on the low side (mainly to get some mileage on it and testing for leaks) I am working on something that will allow me to control from inside the car and switch it so the throttle controls it. On long road trips I would like to be able to turn the boost down for better mileage. I will keep my progress up to date on here.
1960 220SE
MB TECH
1960 220SE
Tymbrymi
Klatta Klatta
185
12-01-2009, 04:53 PM #41
So how goes the progress? Smile
John Robbins
Tymbrymi
John Robbins
MB TECH
12-02-2009, 08:03 AM #42
I have been driving the car daily since september and no problems at all, with the boost turned down (8-10psi) I notice better response and better fuel economy. Still playing with ideas of controlling the turbo from inside the cabin - nothing yet.
1960 220SE
MB TECH
1960 220SE
Tymbrymi
Klatta Klatta
185
01-26-2010, 04:11 PM #43
Any more updates? Angel
John Robbins
Tymbrymi
John Robbins
MB TECH
01-26-2010, 05:56 PM #44
Still running strong, have some issues when boosting 15psi for long periods of time the hose pops off the intake manifold. I got a hold of an other manifold that I will modify and then swap out. Other than that everything is good.
1960 220SE
MB TECH
1960 220SE
01-26-2010, 08:45 PM #45
Using a t-clamp or worm clamp?
MB TECH
01-27-2010, 06:20 AM #46
all T clamps, but where I am on the intake manifold it is tapered so if you tighten too much it walks off. It works fine for now until I come up with something for the other manifold.
1960 220SE
MB TECH
1960 220SE
Tymbrymi
Klatta Klatta
185
01-27-2010, 10:49 AM #47
(01-26-2010, 05:56 PM)MB TECH Still running strong, have some issues when boosting 15psi for long periods of time the hose pops off the intake manifold. I got a hold of an other manifold that I will modify and then swap out. Other than that everything is good.
Nice! I need to come down there sometime and check it out Smile
John Robbins
Tymbrymi
John Robbins
HoleshotHolset
01-28-2010, 05:15 PM #48
(08-21-2009, 11:51 AM)MB TECH I drive the car from Mississippi to Wisconsin alot and im trying to push a little more economy.
Care to share what part of WI? I'm a proud resident of America's Dairyland...work in Madison - live up "Nort" a ways.
Beers,
Matt
'07 W211 OM642
HoleshotHolset
Beers,
Matt
'07 W211 OM642
MB TECH
01-28-2010, 05:38 PM #49
Worked in Madison at the benz dealership for about 2 years and grew up in Milwaukee area. just moved down here to the south last year.
1960 220SE
MB TECH
1960 220SE
mike-81-240d
more like mike-84-300d now
427
08-16-2010, 05:39 PM #50
I spy HID's...
mike-81-240d
I spy HID's...
 17 Guest(s)
 17 Guest(s)
