STD Tuning Engine 606/603 in a 123
606/603 in a 123
606/603 in a 123
giezy
11-30-2013, 04:39 PM #1
got good deal on a mint 123 wagon with a blown 617. how much of a 603 will bolt in to a 123 chassie? would the trans bolt up to it or they are different?
giezy
11-30-2013, 05:31 PM #2
I don't figure you mean blown as in it has a supercharger... haha
I believe the starters are on opposite sides.
giezy
11-30-2013, 07:10 PM #3
oil cooler line came off and woman didn't shut it off right away!
just thinkin about having to change the engine anyway. found a 87 rusty(lots of them up here are!) with a 603 just wondered if they swap out mght aswell
giezy
12-01-2013, 01:05 AM #4
I don't think much will bolt up, but I think another guy on here did it with a coupe, I'll see if I can find the thread
http://www.superturbodiesel.com/std/Thre...ily-driver
Okay it wasn't a coupe, but it was a w123
This post was last modified: 12-01-2013, 01:09 AM by sassparilla_kid.
giezy
12-01-2013, 01:58 AM #5
I don't mind fabbiin stuff but just want to know if it will fit with out big mods
This post was last modified: 12-01-2013, 01:59 AM by giezy.
giezy
cho
12-01-2013, 05:29 AM #6
it will fit.
edit: you might gonna need engine mounts from W126 300SDL or 300SE... or fab yours....
This post was last modified: 12-01-2013, 05:34 AM by cho.
cho
it will fit.
Tito
12-01-2013, 12:34 PM #7
Its almost drop in. The driveline and transmission mount fit. Only thing you need is to drill a new hole in the chassis and bolt it so that the front bolt holes line up with the back holes from the tranny mount.
With this the engine sits very far to the front. So far that the original fan doesn't fit and needs to be an electrical one.
I don't know of the w126 engine mounts fit with this swap, so i made them myself.
Tito
12-01-2013, 01:17 PM #8
Cho and Tito,
You both are talking about using the 603 trans as well correct?
And would it be the same for a 606?
Cho and Tito,
Tito
12-01-2013, 02:01 PM #9
Yes, But I don't think the tranny will hook up to a 606/603.
I've sadly never even seen an 606 but if it has the same engine mount style I don't see any problems.
Tito
cho
12-01-2013, 02:08 PM #10
take a look Smile
http://www.superturbodiesel.com/std/Thre...conversion
cho
take a look Smile
giezy
12-01-2013, 03:30 PM #11
cool that's what I was looking for I like the hub caps on the 16 they look stock at first! if I put a 603 in first a build 606 would go later.when I have time but I can buy rusty 123 300td's here with 603's so would make a good driver with a bigger and tuned engine in it
my friend keeps telling my to put a small block chevy in it! but want to keep it diesel
giezy
 6 Guest(s)
 6 Guest(s)
