STD Tuning Engine clocking an he351ve?
shredator
ridiculous snail orgy of power
56
08-23-2009, 01:49 AM #1
has anyone else tried to clock the exhaust housing on one of these? I pulled the alignment pin out, and moved it to the position that I wanted. while it was still loose, the vgt gear thing moved freely, like it did before I messed with it, but once I tighten the housing down, I can no longer move it. anyone else had this problem? what am I doing wrong?
shredator
08-23-2009, 03:32 AM #2
Without the pin, there is nothing to stop it from working at any angle. The alignment ring is freely rotating and the housing has no functional parts other than that ring.
Try tightening the housing with the vanes all the way closed.
This post was last modified: 08-23-2009, 03:32 AM by ForcedInduction.
shredator
56
08-24-2009, 04:09 PM #3
tried tightening with the ring all the way shut. still binds up when i tighten it down. Maybe i am tightening too much? anyone know what the v-band should be torqued to?
shredator
08-24-2009, 10:29 PM #4
(08-24-2009, 04:09 PM)shredator anyone know what the v-band should be torqued to?
75 inch lbs. (8.5nm)
This post was last modified: 08-24-2009, 10:29 PM by ForcedInduction.
