Torsen diff
Torsen diff
Hi. I just bought two Torsen AMG diffs for 500se to install in my w123. Has any of you driven a car with a diff like that? How easy will one wheel spin? Would it drift easy?
Mattis
got pictures of the inside?
Picture of diff:
thats sweet!
where did you find that? and will it fitt inside the housings? custom build?
It is an original Diesen Torsen diff that AMG used to mount on the cars that they modified. So it should fit inside all W126 V8 housings.
(11-25-2013, 04:44 AM)mercemann It is an original Diesen Torsen diff that AMG used to mount on the cars that they modified. So it should fit inside all W126 V8 housings.
Ratio shouldn't change. The Torsen replaces the ring carrier and sun/planet gears, it uses the same ring and pinion as a regular diff.
You can buy these new from Quaife.
http://quaife.co.uk/shop/search/results/...C267%2C925
(11-25-2013, 05:36 PM)swampmonkey Where can i find one and what ratio will it result in?
(11-25-2013, 09:05 PM)mxfrank Ratio shouldn't change. The Torsen replaces the ring carrier and sun/planet gears, it uses the same ring and pinion as a regular diff.
