STD Tuning Engine turboing the m111
turboing the m111
turboing the m111
12-03-2013, 10:07 AM #1
hello fine people,
it has nothing to do with diesel, but is mercedes so maybe someone can help me.
i want to install a turbo in one M111.960, but i have no clue about works on gas engines. can someone direct me in a good source of info.
regards
FD.
hello fine people,
regards
FD.
12-03-2013, 11:18 AM #2
The performance paddock over on peachparts is probably your best bet:
http://www.peachparts.com/shopforum/perf...e-paddock/
12-04-2013, 03:47 AM #3
thanks ill take a look on it
12-04-2013, 05:37 AM #4
Hi! It would probably be easyest to take a 230 compressor (M111.975) engine and replace the supercharger with a turbo. It's allready got all you need for charging.
There's a book by Corky Bell (Maximum boost) that is recommended as a basic understanding of turbo charged (gasoline) engines. I always start with a good book, internet discussion is - well, we all know the problems Wink
'88 300CD Turbo Coupé - OM603
DiseaselWeasel
12-06-2013, 04:19 AM #5
thanks mr weasel, well f i had one m111 compressor there was no need of going turbo, was just a qustion of tunning it. anyhow i got your point.
the fórum , well they are what they are , all are alloud, u got to filter what u hear. and the same happens with the books, not all have correct info.
now im fighting the CO emissions, does anyone know how to trick them? got to reduce CO by 2%. wich is not much but is required by law.
regards
FD
regards
FD
Tito
12-06-2013, 06:23 AM #6
High CO comes from rich combustion. You could try and fool the ecu by making a small bypass after the mass airflow meter. So the ecu thinks less air is drawn in and injects less fuel. And then the bypass give extra air so your mixture is leaner.
I'm a MOT tester in my country and I can tell, the CO check sucks. Only 0.3% is allowed here.
Tito
12-06-2013, 07:17 AM #7
Thanks for your opinion, it is quiet the one i have, i just dont know if it works. i´ll try. once i had a Subaru impresa and it was the same, always failed the CO emissions, so a acuainted of mine showed me a tap in the manifold that u can remove and the CO was ok after.
This car i´m having the problema is a w124coupe with the M111.960 N/A . maybe u know of some trick , hose whatever i can play to get it through the test , i just need to lower it by 2% .
thanks
thanks
mario
12-07-2013, 08:38 AM #8
Is this a high idle test that you are talking about or just a low idle test
mario
12-08-2013, 06:14 AM #9
both tests , the 3000rpm and the idle , the values are same , 2% above limits. something is wrong with that. plugs and o2 probe is ok , CAT is in good shape, i think , but i dont think the CAT got anything to do with it. i m just guessing. u think lean it would play the trick? i don´t even know how to lean it.
