STD Other FS / WTB / Buying guides Relisted - Selling My OEM Turbo - Complete (Manifolds / Air Cleaner)
Rudolf_Diesel
Ask me if I care...
07-18-2009, 07:45 PM #1
You are bidding on a complete Garret Turbocharger that will fit any OM61x Mercedes Diesel Engine, It was removed from my 1982 300SD OM617.xxx engine. It was rebuilt about 2 months ago and used on my vehicle for about 500 miles. I removed it because I installed an after market Hybrid T3/T40E, I am building a "Super Diesel". The EGR has been welded and the exhaust manifold has been sandblasted and painted with high temp paint, the turbo exhaust and center housing has also been painted with the same high temp paint. The intake was completely cleaned of crud and just needs the EGR block-off plate. If you are buying this to convert your engine then you can probably make the plate too. I am also including the stock air cleaner and plumbing. The only thing that is not included is the oil feed and return for the turbo, you will have to source them from a bone yard - pretty easy to find. This is an easy way to install a turbo on your normally aspirated engine or to replace worn or damaged parts on you turbo engine.
Here is the link
http://cgi.ebay.com/ebaymotors/ws/eBayIS...X%3AIT[/b]
This post was last modified: 08-24-2009, 09:55 AM by Rudolf_Diesel.
Rudolf_Diesel
Here is the link
Rudolf_Diesel
Ask me if I care...
08-24-2009, 09:56 AM #2
Relisted on ebay, lower price!!!
Rudolf_Diesel
