M fuel pump capabilities and adjustment
I have an OM662 (SSangYong) with an STT turbo kit. It has an M pump with the vacuum operated fast idle and no ELD, stock 5.5mm elements. (pump picture: http://i.imgur.com/VJfjrFV.jpg)
I'm exploring options for more power. Most obvious is to throw the pump in the bin and get a modified pump from dieselmeken. I do think I need to get a feel for adjusting this one first, max it out before I replace it. Currently it runs so clean you wouldn't know it was a diesel.
So question #1: How much power can a 5 cylinder M pump with 5.5mm elements support at the crankshaft? Bosch documentation says about 25hp per cylinder.
Question #2: Is there a definitive guide available to how the governor in the M pump works or how to adjust it for max performance in such a way that still lets it return to idle when you lift off the throttle?
So far all the information I have come across is really for the MW pump and the M-pump information is either contradicting, missing pictures to explain which part they're talking about or just flat out wrong. Lots of mention of a rack limiter which the M pump doesn't have (the full load screw affects everything, not just max rack travel), throttle stops not found on the M pump and conflicting info on idle control (Surprise, all 5 screws on the back affect the idle, none of the guides mention that fact).
Everyone seems to know that the pumps won't return to idle if you touch any of the 5 screws on the back, but I have not come across a definitive answer of how to fix that while still retaining any kind of performance.
Question #3: can an MW pump be fitted as a drop-in replacement for the M pump?
(12-07-2013, 04:07 PM)baldur Question #2: Is there a definitive guide available to how the governor in the M pump works or how to adjust it for max performance in such a way that still lets it return to idle when you lift off the throttle?
(12-07-2013, 04:07 PM)baldur Question #3: can an MW pump be fitted as a drop-in replacement for the M pump?
I was just thinking if I can get my hands on an MW pump off a turbo 605 or something that might be a worthwhile upgrade since Bosch rates the MW pump up to 50hp per cylinder while the M pump is only rated to 25hp per cylinder in the Bosch literature.
What settings are there for minimum throttle on the M pump? The linkage returns as far as the lever wants to go, I can't tell if there's a screw somewhere that I'm missing.
(12-09-2013, 05:22 PM)baldur I was just thinking if I can get my hands on an MW pump off a turbo 605 or something that might be a worthwhile upgrade since Bosch rates the MW pump up to 50hp per cylinder while the M pump is only rated to 25hp per cylinder in the Bosch literature.
