STD Other Projects 1991 300D
1991 300D
1991 300D
  • 2 Vote(s) - 4.5 Average
Pages (2): Previous 1 2
Duncansport
09-11-2013, 07:03 PM #51
(09-11-2013, 03:51 PM)Jetmugg Very cool project. I have an OM602 turbo in a 190D.
I would like to have Dieselmeken rework my pump in the near future. I had him/them do a VW injection pump for me, and it is top notch.
The worst part is the shipping cost to and from Sweden, however. For my VW pump, Goran sourced a pump for me over there, built it, and shipped it to the USA.
It was cheaper for him to find a donor pump in Sweden than it was to ship my pump from the USA to Sweden.
How was the shipping cost for your 602 pump to and from the USA to Sweden?
Steve.
So shipper was'nt horrible from here. I used the USPS and it was around $100. Best of it was there in less then 4 days
Duncansport
Steve.
Duncansport
09-12-2013, 10:42 AM #52
Pictures of the H&R cup kit as well as new rear control arms.
Duncansport
09-15-2013, 05:32 PM #53
Care to share the wire diameter of these springs?
Duncansport
09-17-2013, 11:24 AM #54
(09-11-2013, 11:56 AM)raysorenson Did you go with a red plate? What disc?
Clutchnet's website stinks, so dont rely on their red, blue purple listings. Just call them, they always need to make the stuff from OE parts or full custom.
I sent them a 16V pressure plate and disc that they are modifying.They are building a custom friction disc with a HD organic material, don't get caught up in Kevlar or carbon Kevlar as they do not last long and offer only marginal holding power over HD organic, also they glaze very easly is slipped to much. I ran a 6 puk on my old Starion and it held great but was mostly undrivable, so hopefully i don't need to go that route..
Duncansport
Duncansport
09-23-2013, 10:54 AM #55
(09-15-2013, 05:32 PM)raysorenson Care to share the wire diameter of these springs?
Rear is 14mm
Front is 14.5mm
Duncansport
Rear is 14mm
Front is 14.5mm
Duncansport
10-24-2013, 07:22 PM #56
:::SIGH::::
For those who follow you may have know my car clattered to an end the other night. Brand new valve broke at the top.... Hence my search for a 605 now.
Duncansport
:::SIGH::::
10-24-2013, 08:31 PM #57
Ouch, sorry to hear that man.
Time to upgrade Wink
10-24-2013, 09:39 PM #58
I'm following. I was gonna do all your valvetrain mods to my motor :-(
Any guesses as to the cause?
Duncansport
10-25-2013, 09:23 AM #59
(10-24-2013, 09:39 PM)raysorenson I'm following. I was gonna do all your valvetrain mods to my motor :-(
Shitty AE (Federal Mogul) valves. No reason that should have happened to a valve. No sing of overheating, the car doesn't see much time at 6000RPM. The M103 springs are only 20% stiffer then the OM602 springs so i don't believe that there is to much spring tension on them. Besides M103's use larger valves ( read heavier ) and rev higher with the same keepers, retainers ect.
Duncansport
10-25-2013, 09:38 AM #60
That sucks Can OEM valves be obtained from Mercedes? Is the head salvageable the block looks to be ok minus one piston
Duncansport
10-25-2013, 10:03 AM #61
(10-25-2013, 09:38 AM)willbhere4u That sucks Can OEM valves be obtained from Mercedes? Is the head salvageable the block looks to be ok minus one piston
Oh yeah OE valves are in stock in NJ, head the block has a big dent in it..so it's dead. I would need to machine it, press in 1 or 5 liners, new pistons ect... then maybe try to fix the cylinder head. At that point it's cheaper to get a used engine. Pistons are really pricey,
Duncansport
Duncansport
12-20-2013, 12:43 PM #62
    OM605 on the Boat.......
Thank you JGS600
Duncansport
Thank you JGS600
12-20-2013, 03:17 PM #63
Assuming the 602 and 606 have the same bell pattern can I have your old block and crank for measurements? I only need the rear few inches of block and crank to get it probed out.
Duncansport
12-20-2013, 03:59 PM #64
(12-20-2013, 03:17 PM)Simpler=Better Assuming the 602 and 606 have the same bell pattern can I have your old block and crank for measurements? I only need the rear few inches of block and crank to get it probed out.
Sure you can have it. The 601,602,603,604,605,606 M111, M102, M103 and M104 all have the same bolt pattern bell housing.
Duncansport
Duncansport
01-03-2014, 09:10 AM #65
Got the 717.430 all torn down and rebuilt. New syncro's, MB gasket kit and new counter shaft and main shaft bearings.
Duncansport
Duncansport
01-06-2014, 10:09 AM #66
First 605.962 in NH??
Thanks for all that helped!
Duncansport
Duncansport
01-23-2014, 03:39 PM #67
605 Girdle being cut this week.
.pdf
605 602 girdle.pdf
Duncansport
.pdf
605 602 girdle.pdf
HaavardPYA
01-23-2014, 03:48 PM #68
What gauge are you using? Both egt, boost and back pressure? 52mm? Need link Big Grin
This post was last modified: 01-23-2014, 03:51 PM by HaavardPYA.
HaavardPYA
01-23-2014, 04:13 PM #69
(01-23-2014, 03:39 PM)Duncansport 605 Girdle being cut this week.
Awesome!
Awesome!
Gearbound
In need of a OM606.96x
172
01-23-2014, 05:51 PM #70
Just being nosey but how much did the 605 total come out too? Id love to put one in a 190 16v chassis Smile
Gearbound
Duncansport
01-23-2014, 06:31 PM #71
(01-23-2014, 03:48 PM)HaavardPYA What gauge are you using? Both egt, boost and back pressure? 52mm? Need link Big Grin
http://www.glowshiftdirect.com/3in1-dies...auges.aspx
Duncansport
Duncansport
01-24-2014, 08:30 AM #72
(01-23-2014, 05:51 PM)Gearbound Just being nosey but how much did the 605 total come out too? Id love to put one in a 190 16v chassis Smile
Bought and shipped it was around 900. Lots of little dumb fees along the way
Duncansport
HaavardPYA
01-24-2014, 09:33 AM #73
(01-23-2014, 06:31 PM)Duncansport
Thank you!Smile
HaavardPYA
Thank you!Smile
EDH_Performance
01-24-2014, 11:52 AM #74
I am very curioius what you are gonna do with the oilpumpSmile Longer chain?
EDH_Performance
Duncansport
01-24-2014, 12:27 PM #75
(01-24-2014, 11:52 AM)EDH_Performance
Yeah. Same type of chain as a saab b234, I'll add a link or so.
Duncansport
Gearbound
172
01-24-2014, 01:30 PM #76
Who do i need to contact to get a 605? and the cost was $900 total to your shop?
Gearbound
Duncansport
01-24-2014, 01:55 PM #77
(01-24-2014, 01:30 PM)Gearbound Who do i need to contact to get a 605? and the cost was $900 total to your shop?
I hooked up with a member on here JGS600.. He was very helpful. If your serious PM me and i can explain all the work needed, as there is a lot to be done.
This post was last modified: 01-24-2014, 02:08 PM by Duncansport.
Duncansport
95e300dez
95E300td
89
01-24-2014, 03:35 PM #78
I just bought a set of Deves rings here is the link. $235 I am putting them in a 95 606. Here is a link
http://www.deves.com/devesrings/cars_MERCEDES_BENZ.php
95e300dez
Duncansport
01-24-2014, 03:49 PM #79
(01-24-2014, 03:35 PM)95e300dez I just bought a set of Deves rings here is the link. $235 I am putting them in a 95 606. Here is a link
Nice, that's a great price! I just got a set of Gotez's for $230. Sounds like that price is pretty good, I've heard great things about Deves rings in motorcycles.
Duncansport
95e300dez
95E300td
89
01-24-2014, 05:10 PM #80
Yeah I live right here by Import Parts Specialist the guy there talks highly of these rings. He said when he was a mechanic they wouldn't even use Mercedes rings they would get Deves said they sealed a lot better.
95e300dez
Duncansport
01-25-2014, 11:57 PM #81
Good resource to know!
Duncansport
Duncansport
04-15-2014, 07:26 PM #82
So it's been a slow go here, waiting for the machine shop, parts , etc..
But here i have modified the oil pump and oil pan (due to the girdle)
Turned down some Ford modular spring seats to fit the head
Duncansport
led-panzer
05-06-2014, 07:36 PM #83
How's the 605 coming?
1985 300D 280,000 miles RIP
led-panzer
Duncansport
05-07-2014, 07:37 AM #84
(05-06-2014, 07:36 PM)led-panzer How's the 605 coming?
Good, slow but good. the bottom end is all set. Took a bit of time to modify the oil pump, drive chain, oil pan and get the oil jets installed and adjusted.
Waiting on the cylinder head, and still trying to buy a flange from KKD (which is proving very difficult ) i may just make my own flange and offer up the drawing.
Duncansport
Duncansport
11-14-2014, 07:04 PM #85
Well its been forever getting my cylinder head done as the exhaust valves were on back order from M-B Germany. Heads done with new guides, seats, valves, springs, lifters, welded cam. The engine is 98% back together and should start next week. Ill get some pictures up soon.
Ive also finished building my merge collector.
Duncansport
11-14-2014, 07:10 PM #86
Was the cam welded for a regrind w/same base circle or just to weld the gear to the shaft?
Good to hear of progress on this beast. It was already pretty impressive with shitty trans and a 602.
Duncansport
11-15-2014, 03:57 PM #87
(11-14-2014, 07:10 PM)raysorenson Was the cam welded for a regrind w/same base circle or just to weld the gear to the shaft?
I welded it due to the know slippage. And with adding double the spring pressure and a 1700 rpm rise in rev limit i didn't want it to slip on the cam
Duncansport
Duncansport
11-17-2014, 07:32 PM #88
https://www.facebook.com/video.php?v=102...=2&theater
not sure if this will work for you, had the first start up today...:-)
Duncansport
anjay
1998 E300 Turbodiesel
57
11-18-2014, 04:34 PM #89
Link doesn't work!
1987 300TD - tinker toy
1989 300TE - parts
1991 300TE - backyards decor
1991 300TD - Barrote’s 7.5
1998 ML320 - snow ride
anjay
Link doesn't work!
1989 300TE - parts
Duncansport
11-23-2014, 06:19 PM #90
http://youtu.be/pm8cFG7FPpM
give that a try folks.
Got a lot done this weekend, had to make a transmission cross member, lengthen the shift rods, install the shifter, built new wiring harness as well as the other related wiring and vacuum lines all incorporated into into one. Got the assembly installed in the car. Started striping parts off the old 400E loaner car we had.
Duncansport
Duncansport
11-24-2014, 05:53 AM #91
Some pictures
Duncansport
Some pictures
Duncansport
02-11-2015, 01:37 PM #92
Duncansport
Duncansport
02-11-2015, 07:49 PM #93
well theres some pictures that dont work ;-/. More to follow
Duncansport
02-12-2015, 12:28 PM #94
The manifold work looks great. Are you going to have to rotate that flange?
Forum attachment pics don't work for me using Chrome. I have to left click ->open image in new tab. Off-site pics using the img code seem to work fine.
 23 Guest(s)
 23 Guest(s)
