STD Other Non MBZ Diesel Audi R18 Monoturbo
Audi R18 Monoturbo
Audi R18 Monoturbo
01-11-2014, 10:17 AM #1
Hi!
Very interesting VNT single-turbo setup from the Le Mans Audi R18 TDi (3.7l V6).
[Image: r18_monoturbo03.jpg]
[Image: r18_monoturbo06.jpg]
[Image: r18_monoturbo02.jpg]
[Image: r18_monoturbo04.jpg]
[Image: r18_monoturbo05.jpg]
[Image: 120613-10289.jpg]
Looks like a close-to-perfect setup for V engines!
'88 300CD Turbo Coupé - OM603
DiseaselWeasel
Hi!
tjts1
01-11-2014, 01:21 PM #2
I don't think I've ever seen a turbo with 2 compressor outlets and 2 turbine inlets before. Makes sense for a V configuration engine.
This post was last modified: 01-11-2014, 01:21 PM by tjts1.
[Image: 208104.png]
tjts1
[Image: 208104.png]
Gearbound
In need of a OM606.96x
172
01-11-2014, 05:30 PM #3
Thats very interesting. I wonder how that affects flow and efficiency of the turbo vs conventional?
What is the name of a design like this?
Gearbound
Turbo
01-11-2014, 06:18 PM #4
that is some lovely picture
please more if you have
but inlet and outlet is at least interesting but can not been seen that clearly
combine that turbo with this one
https://www.google.com/search?q=formula+...B650%3B366
and we have some very interesting
(01-11-2014, 05:30 PM)Gearbound Thats very interesting. I wonder how that affects flow and efficiency of the turbo vs conventional?
This post was last modified: 01-11-2014, 06:24 PM by Turbo.
Turbo
01-11-2014, 08:09 PM #5
3208 caterpillar engines had a turbine with two inlets on it
Turbo
01-12-2014, 04:24 AM #6
there is several engines that has that construction, if I am not mistaken this make the radial load on the bearing more even and balanced, that is what it is used in pump construction
I would give a lot to see compressor and turbine map
(01-11-2014, 08:09 PM)MFSuper90 3208 caterpillar engines had a turbine with two inlets on it
Turbo
01-12-2014, 04:52 AM #7
indeed! Smile
[Image: %24_12.JPG]
Nothing new then - just a bit refined.
DiseaselWeasel
indeed! Smile
[Image: %24_12.JPG]
mantahead
01-12-2014, 11:37 AM #8
hi,
anyone know what max rpm the engine runs?
mantahead
hi,
tjts1
01-12-2014, 01:13 PM #9
6.7L ford pickup truck engine has a similar turbo configuration
[Image: 6a00d83451b3c669e20120a58c8219970c-800wi]
Because you know, Murica.
[Image: 208104.png]
tjts1
[Image: 208104.png]
Turbo
01-12-2014, 01:46 PM #10
yes that SST3266VJLNRSU is quite nice Smile
(01-12-2014, 01:13 PM)tjts1 6.7L ford pickup truck engine has a similar turbo configuration
Turbo
01-12-2014, 02:07 PM #11
Ford also used a turbo with two compressor wheels on the 6.7, but from what I read they did away with that for the 2014 model
01-15-2014, 02:56 PM #12
That caterpillar turbine housing looks to have split scroll housing with each inlet feeding its own scroll.
Awesome
Awesome
01-29-2014, 04:24 PM #13
Looking familiar? Smile
Yes, that's F1 in 2014... Welcome back huge turbos!
[Image: cleawyalq7c9h75p8.jpg]
DiseaselWeasel
lgreeley83
Mr. Rumbles
01-30-2014, 06:44 AM #14
That ...um... turbo blanket could be a little bigger I think
lgreeley83
 8 Guest(s)
 8 Guest(s)
