STD Tuning Engine OM Exhaust Manifold Thread
  • 4 Vote(s) - 3.75 Average
lpumb3
617 300sd
141
01-18-2013, 02:25 PM #51
has any one attempted to use the egr port with a small vband External wastegate and a non IWG T3 of some sort ? this would ba on the EGR turbo manifolds.
lpumb3
01-18-2013, 02:48 PM #52
Not that I know of, but it sounds like a good use for the EGR tube
F.R.A.S
01-13-2014, 03:26 AM #53
Here is a custom om605 exhaust manifold on the way to completion courtesy of F-tune Performance in Sweden.
[Image: attachment.php?aid=7054]
[Image: attachment.php?aid=7053]
This post was last modified: 03-05-2015, 08:59 AM by F.R.A.S.
F.R.A.S
ben2go
Diesel Dumby
129
01-13-2014, 08:46 PM #54
(01-13-2014, 03:26 AM)F.R.A.S Here is a custom om605 exhaust manifold on the way to completion courtesy of F-tune Performance in Sweden.
Is that titanium?Looks really good.
ben2go
01-13-2014, 10:31 PM #55
Beautiful exhaust manifold work. Why put the charger so low? Would it fit there if all factory accessories were there? (I don't own a 605, I'm just curious)
F.R.A.S
01-14-2014, 06:10 PM #56
Thanks! No it's normal mild steel (I think that's what it's called in English)
(01-13-2014, 08:46 PM)ben2go Is that titanium?Looks really good.
Thanks! The turbocharger are in the stock alternator position =) It's that low because it's closer to cold air and therefore more efficient. It's also closer to the intercooler and will therefore make less lag. To mount the turbo upwards are a solution you only do if there are no other way to fabricate.
(01-13-2014, 10:31 PM)MFSuper90 Beautiful exhaust manifold work. Why put the charger so low? Would it fit there if all factory accessories were there? (I don't own a 605, I'm just curious)
F.R.A.S
F.R.A.S
05-16-2014, 01:22 AM #57
Hi guys, here is how an exhaust manifold comes together @ F-tune Performance in Sweden.
This is a mild steel manifold for a om606 in a w124 chassis.
Collector made Tongue
[Image: 10264204_319036808244091_6791399921215768408_o.jpg]
Pipes spot welded Smile
[Image: 20140513_124450.jpg]
Port filing Tongue
[Image: 20140514_121859.jpg]
Smooth transition Big Grin
[Image: 20140514_122010.jpg]
More filing Cool
[Image: 20140514_122132.jpg]
Has to be smooth Shy
[Image: 20140514_152722.jpg]
Close up of the wastegate tube filing.
[Image: 20140514_152729.jpg]
Care for a EGT-bung? Or six Big Grin
[Image: 20140514_162109.jpg]
All done Tongue
[Image: 20140514_165746.jpg]
Hope you like it.
F.R.A.S
Port filing Tongue
More filing Cool
All done Tongue
Hope you like it.
05-16-2014, 11:51 AM #58
Nice what kind of EGT gauge are you going to run
05-16-2014, 12:05 PM #59
Looks like ports for Corsa datalogger or something similar, where it logs all data into a computer from each and every cylinder. Very cool technology.
05-16-2014, 12:55 PM #60
That corsa thing is insanely expensive. That's pricing from ten years ago. Check out 14point7's $200 idash. Makes the corsa look obsolete. http://www.14point7.com/products/idash
F.R.A.S
05-16-2014, 02:09 PM #61
Thanks guys. This is for a customer in Holland (The Netherlands), he will run six normal analog EGT-gauges. A lot of gauges but at least he will be safe when going for maximum power. I believe this will be the fastest diesel car in Holland Big Grin
Right now Dieselmeken is building an awesome IP for him Smile
F.R.A.S
ben2go
Diesel Dumby
129
05-16-2014, 02:16 PM #62
(05-16-2014, 02:09 PM)F.R.A.S Thanks guys. This is for a customer in Holland (The Netherlands), he will run six normal analog EGT-gauges. A lot of gauges but at least he will be safe when going for maximum power. I believe this will be the fastest diesel car in Holland Big Grin
Any info on that IP?
ben2go
F.R.A.S
05-16-2014, 02:56 PM #63
8mm Wink But other than that there are no special stuff done what I know of Wink
F.R.A.S
F.R.A.S
08-05-2014, 01:42 PM #64
Did a om605 exhaust manifold last week, finished it of today.
Enjoy!
[Image: attachment.php?aid=7636]
[Image: attachment.php?aid=7637]
[Image: attachment.php?aid=7638]
This post was last modified: 03-05-2015, 09:01 AM by F.R.A.S.
F.R.A.S
Enjoy!
F.R.A.S
09-03-2014, 02:38 AM #65
om606 exhaust manifold for you guys.
[Image: attachment.php?aid=7689]
[Image: attachment.php?aid=7690]
[Image: attachment.php?aid=7691]
This post was last modified: 03-05-2015, 09:03 AM by F.R.A.S.
F.R.A.S
F.R.A.S
10-21-2014, 02:28 PM #66
One of the biggest failures I've seen yet.
om603
And people are actually paying for this stuff Sad
Here's another one!
om605
This post was last modified: 10-21-2014, 02:34 PM by F.R.A.S.
F.R.A.S
om603
Here's another one!
om605
10-21-2014, 03:02 PM #67
Thats special.
Thats special.
10-21-2014, 07:34 PM #68
I've been looking for a pic of an F-tune divided collector, 6 cyl specifically. Are yours better than these? :p
F.R.A.S
10-22-2014, 06:22 AM #69
Hahaha, yea we are Wink We do very little divided actually, but that's the customers choice. How ever if going divided on a 6cy we recommend that you go for a t4 flange instead of a t3. Fitting 3cyl in to less than half a t3 is not super efficient.
I actually don't have a picture either on the computer or my trusted phone (aka camera of choice).
(10-21-2014, 07:34 PM)raysorenson I've been looking for a pic of an F-tune divided collector, 6 cyl specifically. Are yours better than these? :p
F.R.A.S
10-22-2014, 06:38 AM #70
The above 603 manifold looks like my towel rail.
This post was last modified: 10-22-2014, 06:39 AM by Hario'.
Duncansport
10-22-2014, 07:14 AM #71
Look, im a welder!
Duncansport
Look, im a welder!
10-22-2014, 07:46 AM #72
[Image: attachment.php?aid=7734]
(10-22-2014, 07:14 AM)Duncansport Look, im a welder!
Fixed. I guess they were blowing on it for shielding gas
F.R.A.S
10-22-2014, 04:43 PM #73
Ohhh my god Duncan. That's the best yet.
F.R.A.S
10-22-2014, 10:17 PM #74
FRAS, how much would a t3 603 manifold cost about?
Those cast w140 mainfold are hard to find!
F.R.A.S
10-23-2014, 05:52 AM #75
Send me a message mate.
(10-22-2014, 10:17 PM)MFSuper90 FRAS, how much would a t3 603 manifold cost about?
F.R.A.S
Duncansport
10-23-2014, 07:16 AM #76
Last one.. i promise :-P
Duncansport
10-23-2014, 08:31 AM #77
I got mine from ebay.de for ~250 shipped.
10-23-2014, 02:36 PM #78
(10-23-2014, 08:31 AM)winmutt
I've been searching high and low, guess I'm at the waiting game now Big Grin
My hx30 won't mount to the original manifold Sad
EDH_Performance
10-28-2014, 08:11 AM #79
(10-23-2014, 02:36 PM)MFSuper90
Make an adapter?
EDH_Performance
Make an adapter?
capflya
Dreaming of a VNT
309
10-28-2014, 09:37 AM #80
(10-28-2014, 08:11 AM)EDH_Performance
(10-23-2014, 02:36 PM)MFSuper90 I've been searching high and low, guess I'm at the waiting game now Big Grin
Make an adapter?
The flange is right but the US manifolds won't allow a large turbo to fit because of the bypass pipe for the trap ox garbage Mbz put on the cars here.
capflya
Make an adapter?
10-28-2014, 10:39 AM #81
(10-23-2014, 08:31 AM)winmutt I got mine from ebay.de for ~250 shipped.
Make an adapter?
It hangs the turbo in the opposite direction on the trap-ox manifolds, so my exhaust would be towards the radiator and inlet towards the firewall. It would just Be easier to use a non- trap ox manifold Smile
Make an adapter?
10-28-2014, 10:44 AM #82
What do euro-603 manifolds sell for in the US?
'88 300CD Turbo Coupé - OM603
DiseaselWeasel
capflya
Dreaming of a VNT
309
10-28-2014, 01:24 PM #83
I've heard of a range... $250-$350 including shipping. I think someone here got one from ebay.de for $275 shipped to the US?
If you can source some I think we have a market... I'm looking for one if the price is right and a friend of mine would be in for one or two.
capflya
F.R.A.S
11-13-2014, 08:13 AM #84
om604 8mm Diselmeken IP, gt3076r a/r 0,63
Thermal barrier coating on exhaust manifold and turbine housing.
F.R.A.S
Eric78
12-01-2014, 04:00 AM #85
Anyone remember the URL of the site that sells a copy of Jeemu's OM 605 exhaust header?
Eric78
F.R.A.S
03-19-2015, 08:00 AM #86
[Image: 210381-5d3d2a91f353b2a7720bff9177354866.jpg]
om617 getting there Tongue
F.R.A.S
03-19-2015, 09:12 AM #87
Nice! I'll take one!
Matej
06-26-2015, 04:21 PM #88
Could anyone make an adapter flange to bolt an OM603 manifold onto an OM606 head?
Something similar to the Dieselmeken flange, but with extra threaded holes for attaching the 603 manifold and with the size of the round outlet ports matching.
[Image: attachment.php?aid=6832]
I will buy one right away. Smile
Irony.cc
Matej
Irony.cc
hents99
06-27-2015, 09:57 AM #89
Something like this? Bolt pattern is very tight.
It`s OM606 flange with OM603 bolt holes.
[Image: 23544-OM606-603.JPG]
www.elbe.ee - MB performance parts.
hents99
hents99
06-28-2015, 03:28 AM #90
Here is E36 turbo manifold I made to my friends car some years ago. Will not fit Big Grin
[Image: 97799-DSC_0193.jpg]
[Image: 89439-DSC_0209.jpg]
[Image: 38963-DSC_0218.jpg]
I suggest you to make new custom manifold for your engine. Fitting another manifold is really PITA. Position of turbo can`t be change and so on.
I have many exhaust flange drawings. I can check what engines have same cylinder spacing like OM606.
hents99
CRD4x4
CompoundSuperTurboDiesel4x4!
399
06-28-2015, 08:05 AM #91
I've been looking into using other non-MB manifolds too and have found only one possible candidate which is early Jaguar 4.2L inline but turbo manifolds are not common. I overlay a OM606 exhaust manifold gasket and the port spacing seems identical except that the Jag ports are rectangular.
Can anyone recommend a free site I can use to share my pix?
'05 Jeep Liberty CRD - 160k
'06.5 VW Jetta TDI - 230k
CRD4x4
Booster
06-28-2015, 01:07 PM #92
(06-28-2015, 08:05 AM)CRD4x4 I've been looking into using other non-MB manifolds too and have found only one possible candidate which is early Jaguar 4.2L inline but turbo manifolds are not common. I overlay a OM606 exhaust manifold gasket and the port spacing seems identical except that the Jag ports are rectangular.
Use Photobucket. Its free and fairly easy to use.
Booster
CRD4x4
399
06-28-2015, 02:42 PM #93
(06-28-2015, 01:07 PM)Booster
[Image: 20150413_153200_zps5s1qszbn.jpg]
My thinking was to weld on a OM606 flange and port match these then use for a turbo set up.
CRD4x4
F.R.A.S
07-01-2015, 03:03 AM #94
(06-26-2015, 04:21 PM)Matej Could anyone make an adapter flange to bolt an OM603 manifold onto an OM606 head?
Hey man thats OUR flange not Dieselmekens Big Grin
F.R.A.S
Matej
07-01-2015, 05:54 PM #95
(07-01-2015, 03:03 AM)F.R.A.S Hey man thats OUR flange not Dieselmekens Big Grin
Sorry, did not even know that, I just assumed it was his since he was selling it.
It is a very nice piece.
As I said above, if it would be possible to make one to adapt a 603 manifold to the 606 head, I will buy one ASAP. Smile
Irony.cc
Matej
Irony.cc
F.R.A.S
07-06-2015, 01:38 AM #96
I don't think we have a om603 flange on the shelf today otherwise I could help you out right away Big Grin Will take cruise around the welding area in a moment Smile
F.R.A.S
07-06-2015, 10:07 AM #97
F-Tune, you guys made some crazy shit Smile
F.R.A.S
07-07-2015, 01:06 AM #98
(07-06-2015, 10:07 AM)Simpler=Better F-tune, you guys made some crazy shit Smile
Thanks mate Cool
F.R.A.S
Thanks mate Cool
F.R.A.S
02-29-2016, 04:50 AM #99
Did a more "normal" flange for a customer. As you understand the customer will weld his own exhaust manifold on this and therefore we don't put any work in to the surface finish.
[Image: OM606-flanges.jpg]
[Image: OM606-flanges_2.jpg]
F.R.A.S
atypicalguy
08-28-2016, 11:07 PM #100
Half of a new 606 manifold from the same guy who made Sultzi's, Pyry Takkunen.
atypicalguy
 33 Guest(s)
 33 Guest(s)
