STD Tuning Engine High egt and blacksmoke.
HaavardPYA
01-18-2014, 11:29 AM #1
I get a little high exhaust temperatures from my 606. About 8-900 degrees celsius under full load on 4500-6000 rpm. I got Precision 6766 turbo, 140cc Dieselmeken pump and runs 1,7bar boost. There is also a good amount of blacksmoke. Can pump timing do something with this?
HaavardPYA
pmj4147
T04R + TD06
42
01-18-2014, 11:40 AM #2
(01-18-2014, 11:29 AM)HaavardPYA I get a little high exhaust temperatures from my 606. About 8-900 degrees celsius under full load on 4500-6000 rpm. I got Precision 6766 turbo, 140cc Dieselmeken pump and runs 1,7bar boost. There is also a good amount of blacksmoke. Can pump timing do something with this?
return the pump timing to stock(my 602 is in atdc 15deg, idk same as 606)
and reduce the intake temp if you can
but.... my buddy's 7.5mm OM602 2.9L
About 1100~1200 degree c.
i don't think it's too high
2002. 09 Ssangyong Musso SUT
OM662STP + 7.5mm + TD06-25G with customized 84mm compressor(2.4Bar)
2002. 12 Ssangyong Korando
OM662LA 2.9ltr + RS191 5.5mm stock
pmj4147
F.R.A.S
01-18-2014, 12:16 PM #3
Just turn the boost up to 1.9bar and log the difference in EGT. Higher boost = lower EGT.
F.R.A.S
EDH_Performance
01-18-2014, 12:41 PM #4
I was running my 140cc pump at 10-12 atdc...
Wind up the boost, you can basicly lower the exhaust temp with enough airSmile
EDH_Performance
HaavardPYA
01-18-2014, 05:44 PM #5
Needs stiffer wg spring thenSmile cant get more boost.. pump is set on standard timing 15atdc
HaavardPYA
01-22-2014, 11:57 AM #6
hello fine people,
well i did not like what happened after running my 605 at 800ºc , not much but one cylinder dead in idle , lots of white blue smoke, compression on the dead cylinder 10bar or less and the others around 14 , everithing points to valves burned.
i´m amased somebody run on 900ºc and didn´t face the same problems.
regards.
hello fine people,
regards.
01-22-2014, 02:29 PM #7
havaard, retarded timing can certainly cause all of this. Did you modify your prechambers?
Volker407
naturally aspirated
157
01-22-2014, 02:43 PM #8
(01-18-2014, 12:41 PM)EDH_Performance I was running my 140cc pump at 10-12 atdc...
I also vote for timing advance from 15° to 12°ATDC
Gruß
Volker
Volker407
Gruß
Volker
HaavardPYA
01-23-2014, 09:00 AM #9
Prechambers are stock.. Maybe i should try to advance the timing ti 12 then?
I know there are many threads on this, but cant find them.. What method is the best to check timing?
Maybe the turbo spools faster also if i advance it?
Regards
HaavardPYA
Regards
Duncansport
01-23-2014, 11:42 AM #10
(01-22-2014, 11:57 AM)barrote hello fine people,
regards.
I ran my 602 up to 1500+ F all the time and during the disassemble i found no issues or evidence of heat damage.
I think the problem for some of use if that you only know the overall exhaust temperatures. For example. say you have poor air flow to on cylinder or the pump is incorrectly balanced. You will get extreme heat on just one cylinder causing heat issues. Not that i think its practical to monitor all the cylinders for egt, but it is important to ensure your injectors are up to par and who ever did you pump can show the fuel flow being fairly even. I think at some point there could be an issue with the factor intake leaking or no providing enough air flow....but that's probably more for the extreme cases.
Just my thoughts!
Duncansport
regards.
Just my thoughts!
HaavardPYA
01-23-2014, 03:02 PM #11
I believe Duncan here have a point. Does the orginal OM606.910 intake deliver equal amount of fuel to each cylinder? Any experiences? Also have the standard crossover pipe.
HaavardPYA
01-23-2014, 05:25 PM #12
hy ,maybe u guys have a point. but belive me it is not a problem of injection unbalance or bad intake in one cyl, maybe and maybe is because i use my turbo waste gate simply closed , closed . and the head is a N/A one . probably is that 50ºC diff. and another i use to work with turbine engines and very few allow working temps above 850ºC, since turbine engines are heat engines u get my point.
anyway i will have to disasemble the think and i get u posted with the findings.
regards.
regards.
 10 Guest(s)
 10 Guest(s)
