STD Tuning Engine Main Bearing Girdle 605
Duncansport
01-19-2014, 08:54 AM #1
I decided to have a main bearing girdle made for my 605. Dropped off the block, front cover, oil pan and pump to have it measured and get a CAD. Then I'll have it water jetted out of .250 or .400. Biggest issue is dropping the oil pan that distance and not having the trans line up with the base of the pan. Not sure what I'll do about that, cross that bridge later.
I'll get some pictures up as they come.
The point of this post is that I'll put the cad up on the patterns page if anyone wants to have one made. Also this would fit a 602 and with simple drawing a 606/603.
Duncansport
01-19-2014, 08:57 AM #2
So will you have to get Longer studs or bolts to accommodate the girdle?
Duncansport
01-19-2014, 10:45 AM #3
(01-19-2014, 08:57 AM)MFSuper90 So will you have to get Longer studs or bolts to accommodate the girdle?
Yeah much longer, as well as jam nuts, hardened washers and oil pan modification.
Duncansport
Gearbound
In need of a OM606.96x
172
01-19-2014, 05:04 PM #4
pictures will be appreciated Big Grin
Gearbound
hansendk
01-19-2014, 07:49 PM #5
When your are upgrading for high HP change the main bearings use from a OM612 engine they are 50% stronger
they are SPUTTER bearings like the conrod bearings already used in both the OM605 and the OM612.
hansendk
Duncansport
01-19-2014, 08:26 PM #6
(01-19-2014, 07:49 PM)hansendk When your are upgrading for high HP change the main bearings use from a OM612 engine they are 50% stronger
Thank you
Duncansport
Thank you
EDH_Performance
01-20-2014, 03:54 AM #7
Hmm, sputterbearings is for people that treat the engine hard just after cold startSmile They are not stronger than std bearings....So if you let the motor warm up before you beat it to the limit it will be just a goodWink
The sputter bearings are just a little more tight when they are cold, same clearance when they are worm...So perfect for engines that is treated badly by city peopleBig Grin
Have you considered what to do with the front main girdle, regarding the oilpump?
This post was last modified: 01-20-2014, 04:20 AM by EDH_Performance.
EDH_Performance
hansendk
01-20-2014, 06:52 AM #8
That is not correct the hole idea about SPUTTER bearing is that they are stronger invented by MIBA bearing company first used as conrod bearing to deal with the higher load off turbo diesel engine later when CDI came also for main bearings the same also for the trucks OM 444 LA only use as conrod but the OM 500 is also main bearings.
also high load petrol engines use them first that I know the VW 1,8 G60
try Google it and see I just did and look https://www.highpowermedia.com/.../what-are-sputter... there they claim GLYCO invented them that not what I was told back in 1986 but that's like people think that bosch invented common rail.
hansendk
Gearbound
172
01-20-2014, 09:37 PM #9
http://www.mahle-aftermarket.com/MAHLE_A...s/Bearings
some neat information on sputter bearings Big Grin
Gearbound
01-22-2014, 12:35 AM #10
Interesting fact, there is a MIBA bearing plant just half an hour away from my home town Big Grin
 6 Guest(s)
 6 Guest(s)
