STD Tuning Engine C111-IId and C111-III details from Mercedes
  • 6 Vote(s) - 4 Average
Pages (2): Previous 1 2
Volker407
naturally aspirated
157
01-22-2014, 03:11 PM #51
some more pictures from the meeting at Schloß Dyck
http://www.nast-sonderfahrzeuge.de/MB-Ex...p?id=37218
http://www.formfreu.de/2010/08/08/merced...loss-dyck/
Can somebody confirm or correct me that the turbocharger looks like a Garrett T04B?
What size would that turbo be compared to a Holset for example?
Gruß
Volker
Volker407
Gruß
Volker
tjts1
01-22-2014, 03:51 PM #52
Can somebody translate?
[Image: dsc_0912mba.jpg]
[Image: 208104.png]
tjts1
[Image: 208104.png]
Tito
01-22-2014, 05:30 PM #53
After full load, don't turn the engine off immediately.
Probably to cool the turbo of course...
Edit: left 2 buttons say pump L and pump R. Kraftstoff means fuel. So some kind of fuel supply. Zuending I don't know for sure but i thought it was ignition. Starter, well seems obvious. And licht mean lights.
I think the white card is the calculated speed. 3,4,5 Gg are probably the gears (in german = gang)? and the engine RPM on top. Reifen translates to tires and the size is 215/70VR15
HA = hinterachse meaning rear axle (differential). That would be the final drive ratio = 3.07
This post was last modified: 01-22-2014, 05:44 PM by Tito.
Tito
01-22-2014, 06:34 PM #54
Ditto on what Tito said.
How in the world can they get 170mph out of that gearing?
http://wahiduddin.net/calc/calc_speed_rpm.htm says 146.6MPH assuming 5th OD is 0.83 (normal 5th right). According to the calculator their 5th gear is 0.71!!!!
Volker407
naturally aspirated
157
12-22-2014, 10:03 AM #55
Look out for news, due to a press release 2015 will be "The year of the C111" with several presentations and a special C111 exhibition at the Mercedes Museum in Stuttgart.
V8
https://www.youtube.com/watch?v=6J1eZ65SgkE
original OM617A sound
https://www.youtube.com/watch?v=KR8n-8W2bOM
Gruß
Volker
This post was last modified: 12-22-2014, 10:13 AM by Volker407.
Volker407
V8
Gruß
Volker
12-22-2014, 12:15 PM #56
Great Stuff !
Great Stuff !
Volker407
naturally aspirated
157
11-12-2015, 05:08 PM #57
A few days ago I have been to the Museum
Gruß
Volker
Volker407
Gruß
Volker
NZScott
HX30W 73/44mm
398
11-13-2015, 01:44 AM #58
Woooow, nice. I'm a little confused as to which engine this is though. Going by the lack of oil filter housing the block is a 617.910? Which would've been used for the 1976 trials presumably, but the info panel says 1980? The other pics of the C111-IID have the normal filter housings. I see the head has the SLS drive blocked off, did the W115s even have SLS?
Jeez this raises more questions than it answers Tongue
PS- didn't happen to see a part number on that vacuum pump block off plate? lol
This post was last modified: 11-13-2015, 01:46 AM by NZScott.
1977 300D (ex 280) 500,000km
1981 240D 498,000
1975 HJ45 ???,000
NZScott
1981 240D 498,000
1975 HJ45 ???,000
Volker407
naturally aspirated
157
11-22-2015, 06:02 AM #59
(11-13-2015, 01:44 AM)NZScott Woooow, nice. I'm a little confused as to which engine this is though. Going by the lack of oil filter housing the block is a 617.910? Which would've been used for the 1976 trials presumably, but the info panel says 1980? The other pics of the C111-IID have the normal filter housings. I see the head has the SLS drive blocked off, did the W115s even have SLS?
They basically took the engine from a W115 240 3.0D
The oil filter connection is below the injection pump. On the old pictures the oil filter is not the stock one.
Keep in mind that there were at least 3 engine versions. The "C111 orange Diesel 1" , "C111 orange Diesel 2" and the later "silver Diesel streamliner".
The cast number on the engine block indicates, that those engine blocks were  an extra casting with some missing holes so they could drill the holes later were they need them. But still a standard OM617 block.
They then did add several holes for the oil filter, piston cooling and so on. The engine also did get stronger rods, different crankshaft, special turbo pistons, bigger piston pins,....  Those upgrades were always related to the naturally aspirated  engine from the W115.
So the later turbo engine which you could buy in every car is very similar to the engine that drove  the records. There are some small changes like the record car had sodium filled inlet and outlet valves. The later production engine only has the outlet valves filled with sodium.
Oh and forget about what the info panels say. They were written by marketing guys....
The SLS drive on the head is  probably just a "power take-off" in reserve.  Maybe they would have needed an additional water pump, oil pump or whatever. On such a car you want to keep all possibilities.
Sorry, no part number on the block off plate ;-)
Gruß
Volker
Volker407
Gruß
Volker
NZScott
HX30W 73/44mm
398
11-23-2015, 12:25 AM #60
I checked some pics and indeed the oil filter on the earlier cars was a remote one, but still the cartridge style.
I was not aware of 3 versions of the engine, thought there was the IID (orange) of 1976 (190hp) then the silver IIID of '78 (230hp)?
I notice too the head has the pencil glow plugs so maybe the head was changed, would explain the SLS drive blocked off. Very interested in the mods you mention, in the middle of chucking a holset on a 617.912 for 150hp or so you see Tongue
Well what a shame Tongue Those vacuum cover plates seem so common in Europe.
1981 240D 498,000
1975 HJ45 ???,000
NZScott
1981 240D 498,000
1975 HJ45 ???,000
 8 Guest(s)
 8 Guest(s)
