STD Tuning Engine w211 320 cdi
w211 320 cdi
w211 320 cdi
bmartins
02-07-2014, 05:02 PM #1
Hello.
My W211 320 cdi 204hp started shaking...
I tuned it get and 237hp. My tuner told me that 250hp could be reached...
My torque converter started shudder. There is anything i can do besides get it fixed... can i get one bit stronger to hold 700NM? Or the normal one can hold it?
Do you know how make the job?
Here in Portugal no one make the operation....
bmartins
Hello.
Druk
02-07-2014, 05:17 PM #2
What year is it?
Druk
What year is it?
bmartins
02-07-2014, 05:30 PM #3
2004..
bmartins
2004..
Druk
02-08-2014, 03:39 AM #4
OK. I ask because the early cars (including 03 and 04) suffer from what is known as 'the Valeo problem'. This is where certain cars fitted with main radiators made by Valeo get a problem where the gearbox oil cooler fails at a crimp and allows coolant into the gearbox fluid. Symptoms of this include a bad judder. Firstly, if you suspect this you should ask for a Glycol test on the fluid. If it fails this test you will need a new TC and radiator and complete fluid flush. At the very worst a gearbox rebuild.
From Google... https://www.google.co.uk/#q=valeo+radiat...es+problem
http://www.mbclub.co.uk/forums/engine/41...issue.html
This post was last modified: 02-08-2014, 03:53 AM by Druk.
Druk
bmartins
02-08-2014, 04:30 AM #5
Hello.
I check no strange noises....no oil in the Glycol, and no glycol in the oil....
My synthoms are just the shacking of the car...
Great post...thanks.
Does the original torque converter holds 700NM?
uk' pid='60553' dateline='1391848782']
[/quote]
bmartins
Hello.
[/quote]
bmartins
03-09-2014, 04:41 AM #6
Hello.
Someone here in Portugal...advised to to change the o´rings inside the torque converter....
What do you think??
(02-08-2014, 04:30 AM)bmartins Hello.
[/quote]
bmartins
Hello.
What do you think??
[/quote]
Austincarnut
03-09-2014, 09:13 AM #7
you should first service and flush the transmission then readapt it w/ mb's sds, that sometimes clears things up, don't use aftermarket torque converters!
(03-09-2014, 04:41 AM)bmartins Hello.
What do you think??
[/quote]
Austincarnut
What do you think??
[/quote]
bmartins
03-27-2014, 12:26 PM #8
Hello.
For some reason i do not know which my car stopped shacking.....
For now i will upgrade the compressor wheel for a .62MFS instead the original .59 and retouch the remap.....
2 bar is good, right?
bmartins
Hello.
mantahead
03-27-2014, 04:34 PM #9
hi,
sometimes oil runs up the inside of the wiring loom and gets into the gearbox ecu, faulty o ring on gearbox plug.
ecu on rhd is passenger foot well.
be worth a check.
mantahead
hi,
be worth a check.
bmartins
03-30-2014, 12:05 PM #10
ok...thanks
bmartins
ok...thanks
Austincarnut
03-30-2014, 08:15 PM #11
this won't cause a tcc shudder, after failing over the years to stop that leak, they put the control unit on the valve body on the 722.9
Did you ever test for glycol? Any MB dealer has the chemistry set needed to do the test.
(03-27-2014, 04:34 PM)mantahead hi,
be worth a check.
This post was last modified: 03-30-2014, 08:16 PM by Austincarnut.
Austincarnut
be worth a check.
bmartins
04-26-2014, 07:59 AM #12
Hello.
I do not know why..but it stopped and everything is normal now....
I do
(03-30-2014, 08:15 PM)Austincarnut this won not know why but after i 't cause a tcc shudder, after failing over the years to stop that leak, they put the control unit on the valve body on the 722.9
be worth a check.
bmartins
Hello.
I do
be worth a check.
 7 Guest(s)
 7 Guest(s)
