STD Other Projects ye ol turd bucket. 75 w115 300d
Pages (2): Previous 1 2
01-07-2014, 03:28 PM #51
Maybe that's why my heat doesn't work
lgreeley83
Mr. Rumbles
01-07-2014, 04:40 PM #52
Oh SAS! Get it going. You can flash a light through the little grill on side of center console . that's the ac fan...should not be turning. My AC dial was in the off position so I assumed heater fan was on. I was wrong. My ac switch is in the mid high position but the heater fan is on. I have no compressor in it currently so can't say how that circuit is affected. Also with heat on you should have no air from the center vents. No heat comes from there. If you close the vent and find air is still coming through stick a screwdriver through the vent and a linkage screw turned clockwise will close the flap all the way. Mine was still allowing cold air, that's how I know that one. And of course they say if your heater fan is dead wave goodbye to ten hours replacing it. Some have had success squirting oil on it and loosening a siezed fan.
lgreeley83
lgreeley83
Mr. Rumbles
01-30-2014, 02:07 PM #53
Well ugh. Got this car running good in the cold but now I need control arms. Damn shock mount tore through it.
Is it a job worth doing?
Getting really tired of this rusty bullshit.
Maybe I said wrong part name. Rear trailing arm
This post was last modified: 01-30-2014, 02:10 PM by lgreeley83.
lgreeley83
01-30-2014, 03:07 PM #54
I welded a 1/4" plate to my rear control arm when it rusted out. Just add a spacer to the good side and you're rednecked and back on the road.
lgreeley83
Mr. Rumbles
01-30-2014, 03:11 PM #55
Lol this thing is baaadd. I don't think there's much to weld too.
lgreeley83
lgreeley83
Mr. Rumbles
01-30-2014, 05:20 PM #56
lgreeley83
01-30-2014, 05:27 PM #57
Had a boss who welded a couple steel straps all the way across the bottom and curved up around the edges on a 300D with a shock blow out like this, then bolted the shock to them. This gave the car a few more years, but that control arm is shot. Im sure you could do the same thing, but eventually anything you do will be temporary if its that rusted on the inside.
lgreeley83
Mr. Rumbles
01-30-2014, 05:30 PM #58
Lol I'm afraid the spring is gonna go through it. I've sourced a couple out just gotta squeeze the trigger.
lgreeley83
Duncansport
01-30-2014, 09:05 PM #59
yikes, time for that thing to take a trip "upstate" as they say
Duncansport
lgreeley83
Mr. Rumbles
01-30-2014, 09:10 PM #60
I learn with each one of these rust buckets. My first 240 had some pin holes in the control arms. I guess these things are prone to rot. Just like the floors hidden under rubber. And every damn other place :-)
I probably should just assume my 85 has rusty arms too and just buy a couple sets.
Probably put 80 highway miles on it like this in the last two days.
This post was last modified: 01-30-2014, 09:11 PM by lgreeley83.
lgreeley83
01-30-2014, 09:58 PM #61
This is a perfect opportunity for you to fab up some custom pipe control arms!
lgreeley83
Mr. Rumbles
02-10-2014, 02:33 PM #62
Well I am excited to have some California grade arms on their way.
I was thinking good time to do shocks right? I can't find HD bilsteins for the w115. I'm I not searching right?
lgreeley83
02-11-2014, 10:29 AM #63
(02-10-2014, 02:33 PM)lgreeley83 Well I am excited to have some California grade arms on their way.
maybe the classic center can get you a shock part number, at least to compare with 123 rear shocks. The front suspensions are different, but the rears look so similar I bet a 123 would work.
where did you get california grade parts? (you are gonna be annoyed, I got a trans cross member from deliveryvalve that looked showroom new. Put a stop to that nonsense, its covered with rust now, as it should be)
lgreeley83
Mr. Rumbles
02-11-2014, 10:35 AM #64
Delivery valve was the hook up. I think any part that goes on the car from now on will be POR 15 painted. Im thinking im following your footsteps. I don't want to bring a clean rust free car to Chicago that would be a sin. If it's in the junkyard already i'll take the parts though. I'm really hoping to get good at welding my rust holes this summer. Probably be emailing you my partner in rust destruction.
lgreeley83
02-11-2014, 11:50 PM #65
Cool
California Grade parts! Ready to take on the rust belt elements!
(02-11-2014, 10:29 AM)JB3 (you are gonna be annoyed, I got a trans cross member from deliveryvalve that looked showroom new. Put a stop to that nonsense, its covered with rust now, as it should be)
Bwaaahaha! "Put a stop to that nonsense" your killing me!
This post was last modified: 02-11-2014, 11:54 PM by DeliveryValve.
Cool
02-12-2014, 09:23 AM #66
look at those control arms! wow
02-12-2014, 09:26 AM #67
(02-11-2014, 11:50 PM)DeliveryValve
Cool
Parts that clean *almost* make it worth putting up with the rest of CA's BS
Cool
02-12-2014, 01:16 PM #68
(02-12-2014, 09:26 AM)Simpler=Better ...
Yep plenty of BS... But on topic of clean California Grade parts, I rather have them used on serviceable rusty old cars to keep them in the road and have those parts get rusty, than to see them go to waste and get crushed. Because that is what is happening to the majority of these parts. Confused
lgreeley83
Mr. Rumbles
02-12-2014, 05:58 PM #69
I hear that! If I had a barn I'd horde those parts up. No part left behind.
lgreeley83
lgreeley83
Mr. Rumbles
03-06-2014, 06:06 PM #70
Pics!!! We love pics!. So I finally have the car on the lift of my mechanic. I am not ready to mess with this so I will pay the cost.... It's partially apart, at initial glance prognosis is good. Gonna throw some new shocks in there whiles it's apart. Should be driving this guy next week. Arm and skid plate picture that I promised like 6 months ago. Angel
Another pic of the arm.
And JB3. I didn't forget about you. When they are off ill get a shipping quote.
This post was last modified: 03-06-2014, 06:07 PM by lgreeley83.
lgreeley83
03-07-2014, 07:57 AM #71
Apart from the control arms, that thing looks pretty darn clean!
03-08-2014, 10:33 AM #72
(03-06-2014, 06:06 PM)lgreeley83 Pics!!! We love pics!.
[Image: attachment.php?aid=7125]
[Image: attachment.php?aid=7202]
Hole-eee....
I hope your mechanic is going to give you a chance to POR 15 your sub-frame.
This post was last modified: 03-08-2014, 10:39 AM by DeliveryValve.
Hole-eee....
lgreeley83
Mr. Rumbles
03-13-2014, 02:19 PM #73
He didn't drop it all the way. I will be coating it this summer though.
Update. All went together well but the e brake cables are a different length between w115 and 123. Haven't swapped that yet. Gonna pick up car today and drop off next week to do those cables. I know now I'm just getting lazy right?
lgreeley83
Purplecomputer
Slowness 220D
897
03-13-2014, 03:46 PM #74
(03-13-2014, 02:19 PM)lgreeley83 He didn't drop it all the way. I will be coating it this summer though.
No, i dont blame you. After a while you get tired of working on cars. So why not hire someone for an easy job.
and they have a lift, so its easier for them and less of a headache for you.
Purplecomputer
lgreeley83
Mr. Rumbles
03-13-2014, 03:48 PM #75
Shoot I'm even going to let him change the oil. ;-)
lgreeley83
lgreeley83
Mr. Rumbles
05-17-2014, 02:37 PM #76
Been super busy with school.
Had a trans cooling line go out this week. Only lost two quarts. New line in good to go. Flushed coolant real well last week. Still driving.
Think my temp sending unit is bad. temp still reading a little hot.
lgreeley83
 22 Guest(s)
 22 Guest(s)
