STD Tuning Engine Do all cdi engines have same style of injectors?
EDH_Performance
02-28-2014, 10:36 PM #1
I was wondering if the 220, 270, 320 and other cdi engines have the same style of injectors? I am thinking on dimensions and lengthSmile
This post was last modified: 02-28-2014, 10:37 PM by EDH_Performance.
EDH_Performance
Turbo
03-01-2014, 02:17 AM #2
As fare as I know the only difference is that
4, 5 and 6 cylinders but w/s210 and w/s211 has not the same injector since rail pressure has increased from 1350 to 1650 bars
(02-28-2014, 10:36 PM)EDH_Performance I was wondering if the 220, 270, 320 and other cdi engines have the same style of injectors? I am thinking on dimensions and lengthSmile
Turbo
EDH_Performance
03-01-2014, 04:27 AM #3
(03-01-2014, 02:17 AM)Turbo As fare as I know the only difference is that
Okey, thats good to knowSmile Do you know if the body of the injector itself is the same? i have heard that vag 2.5tdi injectors fits cdi engines?
EDH_Performance
Turbo
03-01-2014, 01:46 PM #4
As fare as I remember there is same number on my 270 and 320 and if you look at
http://www.ebay.de/itm/EINSPRITZDUSE-648...58a9879d27 same number
If you have any further information about vag 2.5 tdi injectors fit Mercedes it would be interesting to know since there seams to be a lot of tuning on those engines since I am looking for bigger injectors then those from the Mercedes C30 amg, I will speak with bosch motorsport germany because bosch sweden can not help and though I have offer Diesel meken some payment for finding bigger ones no respond, all information according to bosch shall be accessible in the test equipment.
May I ask what are you up to do?
(03-01-2014, 04:27 AM)EDH_Performance
Turbo
F.R.A.S
03-01-2014, 05:22 PM #5
Here is a couple of small lists on Audi and Mercedes. Hope that can help you guys out.
Audi Smile
Mercedes Cool
Had to cut it in two...
F.R.A.S
Audi Smile
Mercedes Cool
Turbo
03-02-2014, 02:04 AM #6
Thanks FRAS
can you please explain a little bit more, for example what pressure is listed ?
(03-01-2014, 05:22 PM)F.R.A.S Here is a couple of small lists on Audi and Mercedes. Hope that can help you guys out.
Audi Smile
Mercedes Cool
Turbo
Thanks FRAS
Audi Smile
Mercedes Cool
Volker407
naturally aspirated
157
03-02-2014, 08:07 AM #7
Hey,
be careful what you are looking for.
You are mixing Common-Rail injector numbers with distributor pump injector numbers, so that will never ever fit to each other.
Even the change of 1 digit in the last 3 of the numbers can change the whole thing to a different physical injector size. (passenger car --> HD truck)
Gruß
Volker
Volker407
Hey,
Gruß
Volker
F.R.A.S
03-02-2014, 12:20 PM #8
In the red field on the Mercedes list there are specifications.
This was just a list that I found on the computer. I have not checked it out more close. I just saw that you were talking about Audi and Mercedes injectors and thought It could help.
/ F
(03-02-2014, 02:04 AM)Turbo Thanks FRAS
F.R.A.S
/ F
RobMB
03-02-2014, 02:22 PM #9
(03-02-2014, 12:20 PM)F.R.A.S In the red field on the Mercedes list there are specifications.
/ F
Hi, FRAS again....
By the way...i can't see injector's data for my 613.961....
Do you have info about that?
RobMB
/ F
Hi, FRAS again....
F.R.A.S
03-03-2014, 04:06 AM #10
No, sorry...
(03-02-2014, 02:22 PM)RobMB Hi, FRAS again....
F.R.A.S
No, sorry...
RobMB
03-03-2014, 08:46 AM #11
(03-03-2014, 04:06 AM)F.R.A.S No, sorry...
Thanks, anyway, FRAS.
Greetings.
RobMB
Greetings.
 9 Guest(s)
 9 Guest(s)
