STD Tuning Engine Propane
Propane
Propane
Pages (2): Previous 1 2
Rudolf_Diesel
Ask me if I care...
09-04-2009, 04:12 PM #51
Too much of anything is bad! I found this site and it seemed interesting:
http://www.ecoshot.com.au/links.html
The Gov't even gives you an incentive for the system.
Rudolf_Diesel
09-04-2009, 04:28 PM #52
(09-04-2009, 04:12 PM)Rudolf_Diesel The Gov't even gives you an incentive for the system.
LPG is also much cheaper there.
Kiwibacon
09-04-2009, 09:22 PM #53
(09-04-2009, 12:58 PM)ForcedInduction Propane isn't good in a diesel, especially with high compression and indirect injection. The compression pressure alone is enough to ignite (detonate) the propane but you also have the glowing hot ball inside the prechamber.
http://www.offroadexpress.co.nz/video/lpg-idling-diesel
That is my video on my 4wd.
The LPG fumigation rate is 0.4% of the incoming air, the engine is cold and running at idle.
It's a direct injection Isuzu with compression ~18:1.
If it detonates in that at idle, then what's it going to be doing in an engine with higher compression when warm and with extra air heat from the turbo?
Kiwibacon
