STD Other FS / WTB / Buying guides OM603 injector pumps for 7mm elements
winequip_td
03-02-2014, 11:03 PM #1
Hi Im looking for a couple of core m pumps for rebuild. I have been working closely with Giles from performance diesel injection in Markham Ontario and we may have a super pump solution for everyone north of the border. Im looking for a couple of core pumps that we can rebuild with larger elements for testing.
winequip_td
03-03-2014, 12:33 PM #2
Giles is the fellow that does all the rotary pumps for the VW guys correct?
Wimer injection in PA could do it I'm sure. But Göran has already talked to the fellas in Cali.
It'd be interesting to see how Giles do Smile
winequip_td
03-04-2014, 12:12 AM #3
Yep Giles is the same guy, he is a good friend of mine. I'm a mechanical engineer and I designed the elements myself. We have received the first batch of samples so I'm looking for a couple of cores to test them in.
winequip_td
capflya
Dreaming of a VNT
309
03-05-2014, 02:30 AM #4
I have a spare pump I pulled from the junk yard. Are you looking to buy and keep these pumps or are you looking for test subjects? I might be willing to sign up as a guinea pig depending on the cost.
capflya
winequip_td
03-06-2014, 10:42 PM #5
What we are doing is building. 3 different pumps, the original pump off my car. (6mm), another one with 7mm version 1 and another with version 2. Eventually we will sell the extra 2 pumps but I'm not sure when that will be. For right now I think it will better to buy the pumps and chalk it up to R&D. What are you looking to get for it?
winequip_td
