STD Tuning Engine !!! URGENT !!! My engine knocking severely!!
pmj4147
T04R + TD06
42
03-19-2014, 02:13 PM #1
OM662 2.9 with 7.5mm
2Bar boost, TD06 25G
I changed headgasket to new one, And i lowered compression ratio to about 17.5:1
Re assembled, Changed turbocharger.
THEN THE KNOCK STARTED
And it's killing my mental.
It's too severe.
What's a cause of knock????
I added cetane booster to my fuel, didn't work
Then changed IP timing both way....didn't work...
Lowed compression could be a reason???
Or the injector can be a reason???
Please help me..... it's going to kill my engine soon.
I have to stop it.
This post was last modified: 03-19-2014, 02:16 PM by pmj4147.
2002. 09 Ssangyong Musso SUT
OM662STP + 7.5mm + TD06-25G with customized 84mm compressor(2.4Bar)
2002. 12 Ssangyong Korando
OM662LA 2.9ltr + RS191 5.5mm stock
pmj4147
It's too severe.
I have to stop it.
erling66
SuperDieselVan
294
03-19-2014, 02:36 PM #2
Try to loosen one injector line at a time, then you will know if it is an injector. And make a video, put it on youtube with a link here.
HuhCoolTongue
erling66
HuhCoolTongue
john
03-19-2014, 02:48 PM #3
Check your timing. Maybe the chain has jumped on notch during disasembly
Holset power!
john
Holset power!
hansendk
03-19-2014, 06:55 PM #4
are you sure that your new gasket is for 89 mm pistons and not for 87 mm.
how did you lower the compression machine the pistons or what.
hansendk
