STD Tuning Drivetrain how common is the factory w126 clutch pedal cluster?
NapaBavarian
03-22-2014, 05:43 PM #1
I have 2 projects, an 82 300sd om617 that needs a 5 speed, I have an om617 flywheel and pressure plate, busted late 80s 5 speed, plan to get parts from pick n pull, 4 speed for bellhousing and some parts from a 5 speed. Looking for an om606 turbo to fit into an sec coupe, already have a 5 speed and flywheel.
I could build a mess of a clutch pedal but the factory clutch pedal is nice and tidy and easy to ship from europe.
NapaBavarian
lgreeley83
Mr. Rumbles
03-22-2014, 06:57 PM #2
Rare but don't take my word for it. I've been on here a couple years and this is the second time I've heard 126 and clutch in the same sentence.
Only the second...
This post was last modified: 03-22-2014, 06:58 PM by lgreeley83.
lgreeley83
Only the second...
03-23-2014, 10:49 AM #3
I had mine shipped from a salvage yard in Germany. Then some one found me a second one at a pick n pull yard here in the states. They only came as a rare euro option in the w126 280s or 280se mostly for hotels and limo company's
03-24-2014, 06:56 AM #4
Im pretty sure the 123 chasis pedal assembly can be easily adapted. I think you just have to cut off the upper hook. To be sure, check out sirnik's 126 thread over on peach parts. I think he used a 123 pedal cluster in his 300SD 4 speed project
03-24-2014, 04:39 PM #5
You also have to lengthen the w123 pedals about 4"
NapaBavarian
03-26-2014, 03:21 PM #6
Thanks, if I ever get my coupe I'd probably look for euro, I might grab a cluster when I find a 4 speed donor 240, I have a couple spare w126 auto assembelies I can use for parts.
NapaBavarian
