Pump timing setup
Pump timing setup
This is all in reference to the MW pump, as it is pretty easy to adjust externally with shims.
How do you tell where the timing's at cylinder to cylinder? A simple dial indicator wouldn't do it as what you're trying to find is where the spill port is in relation to the plunger. I think you'd have to do it dynamically to get any kind of accuracy. Taking a video of the injectors popping on the bench, noting the time between each injector letting fuel go and adjusting from there would probably work. High speed cameras were not around back when these were thought up, and they're still out of my experience range.
Oh hell, I think I just answered my own question. Stick a degree wheel on the end of the cam and drip time them all together. They should be 90 degrees apart on the 4 cyl pump I'm playing with.
Thoughts on this?
PM user OM616 he's been playing with a DIY bench in his spare(haha!) time
https://www.youtube.com/watch?v=iq2FawDlKZ8
P-serie but the procedure is the same whit all inline pumps
I made special tooling and measure the height of the fill port on each barrel. Then I use a rotary table (instead of just a regular degree wheel) to rotate the cam to the proper angle for each element, and set the height of the barrel using a dial indicator and the previously measured port height .
I cross check the timing using the traditional method when bleeding the air from the lines during set up on the calibration machine. This provides a second method to confirm that everything is as it should be.
However you go about it, the important thing that needs to be achieved is to have all the elements evenly timed to each other, at the same amount of cam lift.
By the book the #1 element is set with a dial indicator using a standard port height, and the remaining elements are timed using a degree wheel and spill timed from the #1 element reference.
So, OM616, what you are telling us is you are playing Spin the IP?
Seriously, you are using like a mill style rotary table affixed to the input & holding the casing still & measuring off of a set point on the IP?
Ed
(03-29-2014, 01:15 PM)dieselmeken https://www.youtube.com/watch?v=iq2FawDlKZ8Thank you for sharing your knowledge. I'd looked over your videos but somehow I missed that one.
(03-29-2014, 05:16 PM)OM616 Then I use a rotary table (instead of just a regular degree wheel) to rotate the cam to the proper angle for each element, and set the height of the barrel using a dial indicator and the previously measured port height .Be easy enough to adapt the cam to my 12" rotory table and mount the case to the base. Don't have to worry about the spring tension behind the followers while rotating it then.
(03-29-2014, 06:12 PM)yankneck696 So, OM616, what you are telling us is you are playing Spin the IP?
Ed
(03-29-2014, 07:18 PM)[486] Be easy enough to adapt the cam to my 12" rotory table and mount the case to the base. Don't have to worry about the spring tension behind the followers while rotating it then.
(03-29-2014, 07:18 PM)[486] I don't have to worry much about timing the first one with any kind of precision, just getting the splits between them as close as I can. The actual timing will be mostly by ear once it's on the car and running.
(03-29-2014, 07:18 PM)[486] Then the delivery amounts should be easy enough to match to each other by spinning the whole mess on the lathe and using 4 graduated cylinders. Match the injectors to their respective cylinders and all.
(03-29-2014, 07:18 PM)[486] Mostly I'm asking all this because in the future I'd like to upgrade to the 10mm chinese elements for the quicker injection duration.
Ed
Bosch's (Along with most other manufacturer's) tolerances are for production runs. If they all went exactingly, the price point would be too high. If I had equipment & time, I would be as precise as you are. But, alas, I am just a poor boy, nobody loves me..... Oh, I digress into song. Was that a butterfly?
Ed
(03-29-2014, 09:57 PM)OM616Thinking on it, wouldn't setting it (the barrel) too low result in the injection event being more drawn out, as the cam is at a different section of its profile? It'd probably have the fastest ramping part of the stroke wasted in over travel with the spill port open to the helix.(03-29-2014, 07:18 PM)[486] I don't have to worry much about timing the first one with any kind of precision, just getting the splits between them as close as I can. The actual timing will be mostly by ear once it's on the car and running.
Not correct!! This thinking can/will get you into a lot of trouble.. It is important that the start of injection (the closure of the fill port by the ascending plunger) needs to take place at a specific amount of plunger lift.
It is very important that the #1 element be properly set at the correct plunger height...
(03-29-2014, 09:57 PM)OM616Well, that's an awful lot of money to spend.(03-29-2014, 07:18 PM)[486] Then the delivery amounts should be easy enough to match to each other by spinning the whole mess on the lathe and using 4 graduated cylinders. Match the injectors to their respective cylinders and all.
Yes that can be done, just know that you will be calibrating the tolerance of the injectors into the pump, so if you change injectors the delivery balance will go to hell.
There are special calibrated and balanced master injectors that are used to balance the elements with.
(03-29-2014, 09:57 PM)OM616Well naturally, not planning to screw with that until the engine's running and all. I'd imagine the helix could be cut to a shallower angle to help smooth the governor operation. I'm largely unaware of other issues, I've searched for threads on them, but don't come up with very much.(03-29-2014, 07:18 PM)[486] Mostly I'm asking all this because in the future I'd like to upgrade to the 10mm chinese elements for the quicker injection duration.
That is a different animal, and is not as easy as just throwing in 10mm elements and racing off in to the sun set lol...
(03-30-2014, 05:36 PM)[486] Thinking on it, wouldn't setting it (the barrel) too low result in the injection event being more drawn out, as the cam is at a different section of its profile? It'd probably have the fastest ramping part of the stroke wasted in over travel with the spill port open to the helix.
Too high seems as though it would limit the fueling at the "wide" end of the helix, as in not getting the most of the usable stroke the cam provides.
(03-30-2014, 05:36 PM)[486] Well, that's an awful lot of money to spend.
Think that they could be balanced with just the delivery valves holding back pressure? Then it would be calibrated independently of the injectors. Though there has to be a reason that the big guys use injectors, just wondering if it is some reason that can be ignored in my application, like setting the amount of fuel output to spec.
(03-29-2014, 07:18 PM)[486] Well naturally, not planning to screw with that until the engine's running and all. I'd imagine the helix could be cut to a shallower angle to help smooth the governor operation. I'm largely unaware of other issues, I've searched for threads on them, but don't come up with very much.
(03-29-2014, 07:18 PM)[486] Really starting to regret passing up on that KO lee tool and cutter grinder that was on craigslist for $600 a couple months back... Would be absolutely perfect for changing the helix, among other things.
(03-31-2014, 10:09 AM)OM616 Fill time can suffer if you go very far, the cam is very radical, so it does not take much to have a very large effect that can be negative.Ah, so the rotation is such that delivery is on the fast ramping section of the cam. Really strange looking asymmetrical things...
There is one way to find out lol... Lessons are best learned the hard way some times..
(03-31-2014, 10:09 AM)OM616 No, you need the high pressure to calibrate for leakage and DV operation. There are no short cuts when it comes to quality. You get out of it what you invest into it.Ah, okay. Thanks for saving me that amount of dicking around. I have no real issue with keeping the injectors matched as a set and having to recalibrate the pump when changing them.
(03-31-2014, 10:09 AM)OM616 Been there and done that with the first 10mm elements. Later after talking with some very knowledgeable people on this forum, I came to learn that my understanding of how the system works was wrong, and after doing some math, discovered that I did not need to reangle the helix, but rather select the proper parts. I chose some different elements and DVs that should be good for what “I” want to do, but I have not had a chance to run them yet.Shouldn't the fill port be sized to the element already, as it is drilled in the barrel? Or is this one of those higher RPM things? I can see cavitation being an issue pretty easily.
I will say that the helix on the China elements is the quality issue with them, I now just touch them to match them up to each other in the set. I also add an additional fill port in the barrel.
(03-31-2014, 10:09 AM)OM616 You will also need some special tools to disassemble and reassemble the MW pump.The tappet lifting tools? Easy enough to turn them out of some junk stock I've got around (old CV axles make great carbon tool steel, just lop the joints off and throw the shafts in a bonfire to anneal), take a couple days of free time, not much at all.
The Governor will work fine if it is adjusted properly, so little is known that people think the worst.
(03-31-2014, 10:00 PM)[486] Shouldn't the fill port be sized to the element already, as it is drilled in the barrel? Or is this one of those higher RPM things? I can see cavitation being an issue pretty easily.
(03-31-2014, 10:00 PM)[486] I had ideas of cutting timing advance into the elements to have a milder running engine at low throttle amounts, but I suppose that would be tough to do because I'd need to start with an element that had a retard notch already cut, otherwise further cutting would just result in a dead spot where the spill port would just be uncovered all the time. Maybe that could be compensated for elsewhere. The top end would be unusable anyways, so maybe it would just move the "fueling zone" a little bit over in the rack travel.
(03-31-2014, 10:00 PM)[486] The tappet lifting tools? Easy enough to turn them out of some junk stock I've got around (old CV axles make great carbon tool steel, just lop the joints off and throw the shafts in a bonfire to anneal), take a couple days of free time, not much at all.
Good to know on the governor.
(04-01-2014, 10:52 AM)OM616 Personally I am not a fan of using the elements to control timing as each one is positioned differently depending on the delivery balance adjustments that were made.Ah, so there is an advance mechanism in the timing case that I should have grabbed when I got my pump from the junk yard. Damn.
IMOP, all timing manipulation should be handled by the timing mechanism. I will be setting mine up to come in partially after starting, providing a less advanced position for starting, and once running advance to the bottom of the curve. Then I want to have full advance in by 2K or sooner.
(04-01-2014, 10:52 AM)OM616 The Tappet Holders are very special tools. These hold the lifters off of the cam and are inserted after the lifter is depressed with a press of some kind.
But before you can use the tappet holders, you will need a Welch plug puller to remove the Welch plugs.
(04-02-2014, 09:03 PM)[486] The tappet holders I've seen in videos look to be a tube with a rod with an eccentric on the end. For expediency's sake get some seamless tubing for the outer barrel, and turn some eccentrics to pin onto drill rod for the eccentric bit. Weld a nut to the other end of the drill rod to make turning the eccentrics easy.
All together a lazy day's work. I can't make a splined socket for the DV holders, however, so I'll have to buy one of them.
(04-03-2014, 08:29 PM)OM616 The splined DV holders are on M pumps which use one type of Tappet holder, and regarding making MW tappet holders..... Let me know how that works out lol...
(04-04-2014, 01:35 PM)[486] . I'm starting to accept that IPs are f'in magic, like the rest of everyone already has.
Learning a ton here. Any good links toward info on this?
(04-04-2014, 04:38 PM)OM616 there is also lots of incorrect information posted so you have to weed through it all.
