STD Tuning Engine Custom air filter systems
  • 1 Vote(s) - 5 Average
02-23-2009, 07:08 PM #1
Lets show off what we have for modified air filtration and/or crankcase ventilation.
I promise not to be too hard on you people with direct hot air intakes. Wink
This is my current system. Its from a 1985 300D Kalifornia model. The filter costs $50 but thats only a small compromise since it only needs replaced once a year.
MB was genius when they designed this box. Everything fits in place with only 4 screw holes to be drilled, the clean air outlet swivels easily in the housing allowing one part number to work in two different car models, the air filter has a hair more surface area than the large one used in the 87 300D/SDL and its a true cold air intake.
Two stud holes and a screw
The fitting for the restriction gauge can be seen in the outlet bowl. The whole outlet swivels meaning the tube isn't in a fixed location/angle. The air filter moves with it so there is no sealing issue.
The restriction gauge can be seen on the far left. That allows me to get the maximum useful life out of the filter by knowing when its full instead of just guessing and changing it when it "looks dirty". Eventually I'll add a "shark gill" fender inlet similar to the 87 190D/300D 2.5, but until then the cold air inlet will be plumbed to the old A/C receiver/dryer hole.
    [Image: 190dentrf.jpg]
One screw on the front bracket fit into the stock snorkel hole but I had to drill a new hole for the other screw. The other bracket uses the existing coolant bottle mount. The CCV is a crankcase depression regulator/valve from a VW Passat and 3/4" hose. It limits maximum crankcase vacuum and it works as a rudimentary oil separator. Another benefit is increased crankcase airflow capacity, important for old engines with a bit too much blowby. Turbo manufacturers want no more than 0.1psi of positive crankcase pressure so its important it not be restrictive.
The outlet tube had to be cut short due to how low my turbo sits. The filtered air tube is ABS pipe from a local hardware store. One of these days I'll make a nice aluminum tube to replace it.
So far I'm very happy. Its not as free flowing as my old GM filter with the 3" inlet tube but its (finally!) a true cold air intake that isn't sitting over the hot turbo and breaking mounts. Big Grin
[attachment=240]
This post was last modified: 04-27-2009, 03:57 AM by ForcedInduction.
[attachment=240]
giezy
02-23-2009, 09:16 PM #2
looks good I put a grill in a guys car like that on the left side he put his remote oil filter there as a cooler plus it looked good and matched the right side
giezy
02-24-2009, 02:49 PM #3
I need to find one of these setups. Looks nice and no stupid rattle can with broken mounts....
02-24-2009, 03:10 PM #4
Talk to DeliveryValve over at MShop, he offered me the one from his 300SD. I didn't know at the time that the W123/W126 parts were identical so I got mine from JordaanDMC-12 who pulled it from the junkyard.
This post was last modified: 02-24-2009, 03:10 PM by ForcedInduction.
02-25-2009, 02:26 PM #5
Nice work. I am going back and forth of cramming in a 603 setup or using the other Cali box I have. I got two boxes in my stash. Not as nice as yours both have surface rust on them... Unless you repainted them.
02-25-2009, 04:12 PM #6
Yes, I cleaned and repainted them.
GREASY_BEAST
02-27-2009, 10:52 AM #7
Hey guys,
What do you think about putting an air filter of some sort in the space conventionally occupied by the battery? On the wagon the SLS tank is a little hard to work around, and the battery could be moved elsewhere. I would think an insulated partition would have to be constructed to keep the heat from the turbine and downpipe away, but there is cold air readily available from the fender, and its a dry spot.
GREASY_BEAST
Hey guys,
02-27-2009, 04:01 PM #8
Thats what I'm planning on doing with my next car.
You can also get the SLS tank brackets/hoses from an 85 to move the tank to the drivers side.
This post was last modified: 02-27-2009, 04:02 PM by ForcedInduction.
GREASY_BEAST
02-27-2009, 09:50 PM #9
(02-27-2009, 04:01 PM)ForcedInduction You can also get the SLS tank brackets/hoses from an 85 to move the tank to the drivers side.
I didn't think about that... Seems like a major pain but I guess so is moving the battery..
GREASY_BEAST
09-09-2009, 11:20 AM #10
This is the current system on my 300D. Its a Fram 8038, used on several Chevy pickup applications. 4" tube from the filter mouth to the 2.5" turbo inlet using ABS pipe. Even a year old it only shows 12"h2o at full power.
Next in line is a PowerCore filter from a 2008 Ford F350 with the 6.4L powerstroke. I'm hoping it will fit between the headlight and fender well better than the 6.0L powerstroke filter/housing and the H2 hummer housing (both use powercore filters).
The H2 housing comes very close to fitting, with some modification, but it would also require complete removal to change a filter.
09-09-2009, 11:29 AM #11
I tried out the Jaguar filter and so far it is too small. I will try opening the intake a bit more and see if that is suitable.
jankjerbye
10-01-2009, 08:35 AM #12
Hmm would a relocation of the intake-box give any noticable advantages on an naturally aspirated engine? Colder air=more air pr. intake cycle=better filling??
jankjerbye
10-01-2009, 10:26 AM #13
No its cold air already. Just good quality filter (OE/OEM).
kamel
Naturally-aspirated SUCKS
176
10-01-2009, 03:51 PM #14
Foglight removed for shortram 3".
[Image: IMG_3407-2.jpg]
Also made a new puke tank, but haven't gotten pics yet.
kamel
MB TECH
10-02-2009, 08:46 AM #15
still working on a better air filter setup to grap some ambient air instead of engine heat, the breather is just a puke tube running right in front of the air filter (not shown in these pictures). But as most of our cars are this is a WORK IN PROGRESS.
1979 450SEL 6.9 - stock
1960 220SE
2005 S55 AMG - stock
2006 SLK55 AMG - stock
MB TECH
1960 220SE
1lowdiesel
10-15-2009, 02:00 PM #16
here is my hokey set up
[Image: DSC_3965.jpg]
and my blocked egr
[Image: DSC_3959.jpg]
[Image: DSC_3958.jpg]
1lowdiesel
and my blocked egr
10-15-2009, 05:05 PM #17
I don't see a filter, and your oil return tube is open to collect water and dirt.
1lowdiesel
10-15-2009, 05:19 PM #18
ahh you don't need no stinkin filter lol..
that is an old pic actually. i have an Airaid filter on it now and that return is plugged now. the egr now has been fully blocked and sports a boost gauge port now Smile
This post was last modified: 10-15-2009, 05:20 PM by 1lowdiesel.
1lowdiesel
10-16-2009, 05:15 PM #19
(10-15-2009, 05:19 PM)1lowdiesel ahh you don't need no stinkin filter lol..
So where's a picture of this setup?
Budget_Builder
10-19-2009, 08:00 PM #20
This is my first diesel, first turbo, first Mercedes and my first post on this site. I wanted to simplify the air filter system on mine, and wanted to get the air filter off of the top of the turbo and wanted to start getting better performance. Well 2 out of 3 is not bad Smile. Here are the pictures of my setup.
The crankcase ventilation involved some trial and error, but using ½ “ copper tubing connected to the original openings seamed to be the best choice. Using a tee in the tubing to connect to a PVC hose to the air filter has not dumped too much oil into the air flow (at least not any more than the original filter did).
Budget_Builder
lgreeley83
Mr. Rumbles
04-05-2012, 03:14 PM #21
I have seen this separator on a few cars now, FI and maybe rudolf? Wondering where I can get one like that?
The other one I saw look the same I think.....this looks store bought not fabbed.
This post was last modified: 04-05-2012, 03:15 PM by lgreeley83.
lgreeley83
JustPassinThru
W123 and W124
491
04-05-2012, 03:25 PM #22
Some 240D's had them.
JustPassinThru
04-05-2012, 04:35 PM #23
That's an air line water separator for a shops compressed air system!
usually it mount's on a wall after a compressor before all of you expensive air tools
lgreeley83
Mr. Rumbles
04-05-2012, 05:10 PM #24
(04-05-2012, 04:35 PM)willbhere4u That's an air line water separator for a shops compressed air system!
I thought it was something like that, looked in a harbor freight near me and they didn't have that in their air compressor tool section. Guess i will do some more hunting.
I looked up the 240d ones too. They look a bit cumbersome.
lgreeley83
04-09-2012, 03:03 AM #25
I now have the one from Rudolf.
lgreeley83
Mr. Rumbles
04-09-2012, 07:21 AM #26
Saw something in napa parts yesterday. Pretty but 70$ nope
lgreeley83
04-09-2012, 06:27 PM #27
I've seen them for $15 at Home Depot.
lgreeley83
Mr. Rumbles
04-09-2012, 09:04 PM #28
(04-09-2012, 06:27 PM)aaa I've seen them for $15 at Home Depot.
I guess i have to go there and check. Tried a local true value hardware store today and prices were 60-150. Ugh.
lgreeley83
toyfreak
04-10-2012, 12:12 AM #29
cut the one out of the stock air filter canister, that's what I did. It may not get all the oil from the vapor, but it still gets most of it. I pulled mine apart and threw some steel wool inside and sealed it back up. I also have a lot of blowby.
[Image: IMG_0004.jpg]
toyfreak
lgreeley83
Mr. Rumbles
04-10-2012, 02:19 PM #30
Well that's a fun looking valve cover. To go along with the fram filter those are my high school colors. Go Huskies 2002.
Back on track I got one of those air compressor filters from lowes for 20$
http://www.lowes.com/pd_221014-47120-SGY...&facetInfo=
Any idea on why the cost varies so much on these? I see this is not ANSI certified, not worried about that. Can the quality be that much different?
Still cant decide whether or not to just vent to the atmosphere.....any input on that?
This post was last modified: 04-10-2012, 02:20 PM by lgreeley83.
lgreeley83
lgreeley83
Mr. Rumbles
04-11-2012, 05:16 PM #31
Shit i put it in and my car started smoking like crazy. Big smoke. I took it out and still smokes a lot worse. Grey
I am sure its unrelated but i think my turbo died today
This post was last modified: 04-11-2012, 05:37 PM by lgreeley83.
lgreeley83
04-12-2012, 08:29 AM #32
I vented to atmosphere for a while, you end up with a nice light oily coating under the car :p
 21 Guest(s)
 21 Guest(s)
