STD Other Projects 1982 500 sec om606 8.5mm
Dieselsec
04-23-2014, 02:26 PM #1
I have just finished painting my sec in red. Paint came out ok apart from the runs in the paint that need sorting. Not to everyone's taste but it's different. The jury is out on the painted chrome.
The engine is a 97 om606 fitted with a ppdiesel built pump with 8.5mm elements. Holset hy35 turbo.
I turned it right down as it was throwing out too much black smoke, when cruising. Still needs some adjusting.
The 722.3 held up for the first few miles but is now slipping when changing gears. I believe there is an adjust on the box that can increase the pressure during change.
There aren't too many secs that have been converted.
So anyway I was thinking of a 6 speed manual swap. Any thoughts?
tried to attach a pic but wont work
This post was last modified: 04-23-2014, 02:38 PM by Dieselsec.
W116 om611
Dieselsec
W116 om611
mbdiesel
04-24-2014, 05:48 AM #2
Pictures please! Big Grin
mbdiesel
pryantcc
04-25-2014, 05:51 AM #3
(04-23-2014, 02:26 PM)Dieselsec So anyway I was thinking of a 6 speed manual swap. Any thoughts?
I'm about to attach a 6 speed manual to an OM606. I'm using standard electronic injector pump though, so the gearbox endurance isn't such a big factor for me. I should really start a thread here. I'll get around to it at some point.
pryantcc
Dieselsec
04-25-2014, 02:07 PM #4
(04-25-2014, 05:51 AM)pryantcc
(04-23-2014, 02:26 PM)Dieselsepiit =63148 So anyway l swap. Any thoughts?
Are you going to use the flywheel from the donor car? I was thinking of swapping the whole lot over from a 6 speed e200 kompressor.
Any ideas on how to upload pictures. I tried the attachment option but no pictures appear on my post?
Think I managed one!
This post was last modified: 04-25-2014, 02:55 PM by Dieselsec.
W116 om611
Dieselsec
W116 om611
mario
04-28-2014, 12:41 AM #5
Nice as where are you in Ireland
mario
Dieselsec
05-03-2014, 05:08 PM #6
[quot'mario' pid='63275' dateline='1398663714']
[/quote]
Thanks. I'm in Dublin.
I adjusted the vacuum modulator on the side of the box, I turned it in as far as it would go. Topped up the atf and now there is no slipping between shifts.
I turned the IP external adjustment on boost up about half the travel of adjustment to see if the box could handle it.
Took it out on the road, was boosting at 25 psi at 60mph with some serious acceleration when suddenly a hard pipe blew off the intercooler silcone elbow. It was some bang then the cabin started filling with smoke, the hard pipe shot up and severed a live wire which shorted on the chassis and went on fire. Luckily I got it out before and damage.
Video soon.
W116 om611
Dieselsec
[/quote]
Video soon.
W116 om611
pryantcc
05-03-2014, 05:57 PM #7
(04-25-2014, 02:07 PM)Dieselsec
Are you going to use the flywheel from the donor car? I was thinking of swapping the whole lot over from a 6 speed e200.
No, I wanted to avoid the dual mass flywheel. Didn't want to risk it with the greatly increased torque. I've bought a solid flywheel conversion kit for a Sprinter van. Not fitted yet but everything looks and measures perfect except the ribs for the RPM sensor. Doesn't matter if you have mechanical pump, but my pump is still electronic, so I have some slight modification to do, but nothing disastrous.
pryantcc
Ksteen2
05-04-2014, 03:50 PM #8
dual mass flywheel, and much more fuel, and a BIG turbo Wink
since you alredy have 8,5mm Wink
1#
Volvo 940 estate 1995
Originaly a d24tic
6speed cdi box
4,5" humongus cooler
Please wait, loading boost
Ksteen2
1#
Originaly a d24tic
6speed cdi box
Dieselsec
05-04-2014, 04:34 PM #9
(05-04-2014, 03:50 PM)Ksteen2 dual mass flywheel, and much more fuel, and a BIG turbo Wink
What is the turbo lag like on that big holset you are running? I am only running a hy35 but still takes a bit to boost. Once it gets to 5psi it shoots up but I imagine a bigger turbo would be slower especially with the autobox
W116 om611
Dieselsec
W116 om611
Ksteen2
05-05-2014, 12:28 PM #10
I got full boost at about 3-3500 rpm, but you can get a better turbo then the old hx, a newer ball bearing from garrett or something, spools nice, I know :p
1#
Originaly a d24tic
6speed cdi box
Ksteen2
1#
Originaly a d24tic
6speed cdi box
05-06-2014, 09:59 AM #11
Borg Warner FMW S467.7 spool nice for how big they are.
And they flow ALOT of air for their frame size.
Dieselsec
05-06-2014, 03:47 PM #12
(05-06-2014, 09:59 AM)MFSuper90 Borg Warner FMW S467.7 spool nice for how big they are.
Will check that out thanks.
Broke my damn manifold again. Looks like the weld cracked again.
W116 om611
Dieselsec
W116 om611
Tito
05-06-2014, 04:30 PM #13
(05-04-2014, 04:34 PM)Dieselsec
I noticed that my car was faster with the auto box... Why?... The stall speed of the torque converter is about the same rpm as when the turbo begins to spool (±2500 rpm) allowing for a rocket takeoff. The manual tranny need a closed clutch then boost starts (unless you don't care about changing a crispy clutch now and then). Of course the manual is more fun to drive but you'll need to keep it up in the rev's. The auto box had a more luxurious power feeling.
Tito
john
05-12-2014, 04:11 PM #14
a prepped th400 would do the job Smile anyone done it?
Holset power!
john
Holset power!
Dieselsec
05-13-2014, 01:15 PM #15
(05-12-2014, 04:11 PM)john a prepped th400 would do the job Smile anyone done it?
Would I need to do much to it or would a stock th400 hold up?
W116 om611
Dieselsec
W116 om611
john
05-20-2014, 02:42 PM #16
(05-13-2014, 01:15 PM)Dieselsec
you could just buy a preped one from the states acording to your specs. or buy one from a junkyard from an old chevy van and prep it your self. it is a ton of prepkits out there and they are not that expensive. with a ratchet shifter it beats all manuals!!
at least 400 hp in stock gearbox. in the 1960 they put th400 behind 1000hp dragsters so depending how much money you spend it can be unbreakable for a merc diesel.
Holset power!
john
Holset power!
 15 Guest(s)
 15 Guest(s)
