Iveco 2.8t more power?
My Iveco Turbodail van is kinda slow, it has about 105hp, are there any chance of giving it more power, 130hp would be nice
It has mechanic IP, so no chiptuning.
I don't know much about pump types,it has fuel outputs on back side, not inline. (VE maybe?)
Assuming this is the Sofim 8140 engine I believe the higher power versions are common rail so their parts aren't much use to you Are you sure there isn't a computer attached to the pump on this engine? It may be a mechanical pump but computer controlled.
You are in the realms of tuning the pump up and getting more boost from the turbo or fitting a bigger one. Sorry I don't know anything about VE pumps and how easy or hard they are to get more out of.
VE pumps are very simple to get more fuel out of them.
If it is indeed a VE, it should look similar to this:
(sorry for the huge picture)
If you take notice where the injection lines come out of the head of the pump, then look directly upward, there is a flathead screw with a 13mm locknut. Give this a couple turns in, but if the engine starts to return to idle slower, you've went too far. But by then it will be bellowing black smoke Just go a turn at a time until you are satisfied.
The rectangular box on top of the pump can also be adjusted for fuel before boost, but not all pumps have that box.
If you have anymore questions, don't hesistate to ask!
There is no ECU. Yeah, it's VE pump for sure.
I don't think of placing a bigger turbo, what i really need is faster spool and make the engine more efficient
I'm thinking about removing exhaust parts, for more airflow and turbo sound (yeah!)
Should that do a trick?
Adjusting the pump will make the turbo spool sooner. The box on top of the pump controls fuel before boost, and turning that up some can help spool it sooner, just be careful not to turn it up too much, or it will smoke like a freight train
If you google search how to turn up a first generation cummins, it will bring up some nice write ups on how to mess with those pumps. The cummins pump is the exact same, except it is 6 cylinders.
(05-03-2014, 03:19 PM)MFSuper90 Adjusting the pump will make the turbo spool sooner. The box on top of the pump controls fuel before boost, and turning that up some can help spool it sooner, just be careful not to turn it up too much, or it will smoke like a freight train
(05-05-2014, 02:38 PM)kristijan920(05-03-2014, 03:19 PM)MFSuper90 Adjusting the pump will make the turbo spool sooner. The box on top of the pump controls fuel before boost, and turning that up some can help spool it sooner, just be careful not to turn it up too much, or it will smoke like a freight train
Yeah, I heard that many times, faster spool is really what I need
I'm thinking about Arduino and LCD for boost and EGT values
Electronic is complicated , one mechanic guy has same opinion about wastegate mod, so I will do it after
One thing isn't chear do me, does wastegate closes or open when idle and when spools up?
Wastegate is closed at idle. As boost increases, boost is sent to the wastegate diaphragm and that opens the wastegate to allow exhaust gas around the turbine wheel to limit boost
Can I tune wastegate to make faster spool?
I'm afraid of modding pump , what is with fuel consumption and cold start, everyone says that it will take more fuel..
The wastegate is suppose to limit boost. Not delaying spool up time. I don't know about Iveco engines but sometimes on continuous speeds the waste gate is kept open on purpose to limit back pressure and unnecessary heat build-up. But this is delaying spool up time a little bit when you're on the move and want to overtake or something but I doubt it's even noticeable.
Turning up your pump is indeed consuming more fuel. But so is everything when you want to increase power. More power means more fuel. Even if you could get instant boost it's going to consume more fuel because it needs more fuel for the power.
Mod the pump, keep track of ALL adjustments made, and if you like the power and it doesn't consume too much fuel, leave it alone.
But if it consumes too much fuel for your likings, just look at what you wrote down, return it to stock or put it half way in between
I think i should install sport air filter for turbo sound
Right now original filter is clogged and I should fix that first
I will, problem is that I don't drive it at this moment
I have run these Ivecos ....fantastic engines ...a few of them achieved over 600,000km before needing overhaul. They are strong very tuneable and extremely durable. The VE pump is easy to play with so is the wastegate. An extra 25% output should be easily achievable
Guys, sh** happens, have NOT touched the pump since my last post here, and I have big black smoke issues, so I want to fix this first, and after it's fixed, give it a little tuneup.
So, pump is on 100% factory settings, it smokes when accelerating, when engine starting(why??)
I will change air filter and check for leaks first
(10-11-2014, 05:31 AM)kristijan920 Guys, sh** happens, have NOT touched the pump since my last post here, and I have big black smoke issues, so I want to fix this first, and after it's fixed, give it a little tuneup.
I just found out that "clogged air filter" light on dash is not working so I thought that filter is clean.
It ussualy lights up when filter is dirty and needs replacement, mine didn't.
Changed air filter now, it's a bit better, still a little smoke but it passed MOT with no problems.
BTW: it's EURO3 engine with cat back
back on topic:
i have found this http://ivecoforums.com/topic/8813306/1/
Exactly what I need is to climb up using higher gear and sooner boost!
You can see that guy said engine is more lively with this modification, what do you think about it, anyone tried?
And what about timing?
