STD Tuning Drivetrain Clutch woes. Om606 with C250 5 speed
48 Ford
05-26-2014, 12:17 PM #1
Hi guys,The clutch in my truck has started to slip under maximum load.606 engine with the C250 dual mass flywheel and new LUK clutch 3000 miles ago. Any thoughts on something a little better,bearing in mind it's a work vehicle used for towing etc. Thanks and would welcome any ideas.
48 Ford
hooblah
05-26-2014, 03:37 PM #2
What gearbox are you using? You may be able to upgrade to a 240mm dual mass or a single mass from a sprinter if you bell housing's large enough.
If youre lucky someone may do an upgraded clutch kit for a c250?
Other than that youre only solution is custom. You can have the friction disc relined with a material that has a higher coefficient of friction.
It could possibly be a defective clutch and therefore you may be able to exchange it under warranty. Entirely up to you if you want to go down that route...
hooblah
Tito
05-27-2014, 06:14 AM #3
I've read somewhere about problems with not original gearbox that the bearing would keep pressure on the pressure plate.
Tito
48 Ford
05-27-2014, 03:09 PM #4
I just have a standard C250TD box. I have checked the arm and there doesn't seem to be pressure on the bearing. I like the sound of the sprinter single mass conversion if it fits.
48 Ford
48 Ford
06-23-2014, 01:15 PM #5
Used a Spinter (903) kit.Has built in pilot bearing and 240mm diameter. Fits without any mods,just use your own release bearing. Euro car parts no. 633220030. Also on gum-bay for the same sort of price. Hope this is of some use to someone. Much better feel and no more slippage .!!
(05-27-2014, 03:09 PM)48 Ford I just have a standard C250TD box. I have checked the arm and there doesn't seem to be pressure on the bearing. I like the sound of the sprinter single mass conversion if it fits.
This post was last modified: 06-23-2014, 01:17 PM by 48 Ford.
48 Ford
Stevo-trendy
06-23-2014, 03:34 PM #6
What truck/van have you got om606 engine in just out of interest ?
Stevo-trendy
48 Ford
06-23-2014, 03:42 PM #7
(06-23-2014, 03:34 PM)Stevo-trendy What truck/van have you got om606 engine in just out of interest ?
1948 Ford F1. There are some pics in the project section if your intrested.
48 Ford
CRD4x4
CompoundSuperTurboDiesel4x4!
399
07-22-2014, 12:21 PM #8
What's the spline count on the input shaft of your transmission?
'05 Jeep Liberty CRD - 160k
'06.5 VW Jetta TDI - 230k
CRD4x4
 9 Guest(s)
 9 Guest(s)
