STD Tuning Engine Garrett 712120 VNT Hella 6NW 008 412 actuator.
  • 2 Vote(s) - 5 Average
Pages (4): Previous 1 2 3 4
Iangiulu
07-12-2014, 02:42 PM #151
(07-10-2014, 02:06 PM)Iangiulu Hi, I need your help. Did you know if this is working for the MB actuator?
No one?
Iangiulu
No one?
Darqs
12-18-2014, 03:06 AM #152
(07-12-2014, 02:42 PM)Iangiulu Hi, I need your help. Did you know if this is working for the MB actuator?
Yes... if only PWM freq=140Hz.
Best regards,
Darqs
Darqs
Best regards,
Darqs
antonmies
Go MPR
59
01-23-2015, 06:43 AM #153
What type of soldering there is in the leads from the PCB to housing?
There is a broken lead in a servo I'm trying to fix, but the solder I use doesn't seem to stick. Just floats on the surface as a metal ball...
This post was last modified: 01-23-2015, 06:53 AM by antonmies.
antonmies
HoleshotHolset
04-15-2015, 10:37 AM #154
(01-23-2015, 06:43 AM)antonmies What type of soldering there is in the leads from the PCB to housing?
The leads are spot welded from the factory.
I tried soldering these using rosin core solder and flux and did not have any luck.
Attached is a picture of a rather poor attempt at fixing the leads on a "good used" actuator I bought from a gent on another forum.
Beers,
Matt
'07 W211 OM642
HoleshotHolset
Beers,
Matt
'07 W211 OM642
