STD Tuning Drivetrain Alternate manual gearboxes
Biocruzer
07-13-2014, 06:06 PM #1
Wow! What a treasure trove of information I mined from 2 hours on your site!
I have a 1981 NA 300D (OM617) engine mated to a 722.118 auto box, and am thinking of the manual conversion.
As (preferably) 5-speed (4+O/D) boxes are like feathered frogs and 4-speed are almost as rare, and I'm somewhat less than a purist, what options do I have for a non-Mercedes 5-speed manual box? Cast iron would be OK to keep the front end down a bit more. Performance is not an issue, but hassle-free motoring is. Aside from the ancillaries (pedals, master cylinder, etc), what would I need? A W123 bell housing? I'm thinking that a non-MB bell would have to mate with holes in the block, while an original would have to be drilled to fit the non-MB box? A way to mate the driveshaft with the output shaft? Stub shaft if new box is shorter, fixed to flex disc? I'm new at this, but I can visualise what I want. However, time and money usually don't coincide to get the job done Sad , but I'd certainly appreciate any ideas from others more experienced...
Graham
Biocruzer
Graham
07-13-2014, 08:19 PM #2
I am in the same boat you are man. I want a five speed something terrible, but they are rare and outrageously priced. The 5 speed from a 190 (717.41x) can be mated to a 617 with some custom work. Search the drivetrain threads and you can see where one or two fellas have tackled the job.
Torkey
Dirty Diesel
220
07-13-2014, 11:30 PM #3
I am right there with you. Would love to get a 5 speed. The 5 speed from the 190's are a close ration 5. So 5th gear is 1:1 not overdrive.
What about BMW transmissions from that era. Didn't Getrag make those transmissions too? Might make a bell swap easier. Just thinking out loud.
79 300CD
82 300SD
Dirty Little Freaks Racing
Torkey
79 300CD
82 300SD
Petar
7.5mm M pump
459
07-14-2014, 04:44 AM #4
Not exactly.190 transmissions are all overdrive around 0.8:1 EXCEPT the close ratio 5 speed from the 16V models.These are easily recognized by the shift pattern with the dog leg first gear
[Image: 23082009222aLarge.jpg]
These are far less common than normal five speeds
Petar
swampmonkey
hx40 super
280
07-14-2014, 05:22 PM #5
as Petar said, no w201 or w124 gearbox are 1:1 in fifth except the 717.404 in the 190E 2.3 16v and the 717.450 found in some w124 300E variations, both with that dogleg layout, where the Reverse is forward, and the first gear is back...
daily driver
w115 240d 72hp 3.07 rearend
+ a few more.
mbturbo.com
swampmonkey
daily driver
+ a few more.
mbturbo.com
Biocruzer
07-14-2014, 10:18 PM #6
Hi, I know I just asked about non-mercedes 4/5 speed boxes, but these have come up in coincidental search. Both are said to be off 57-64 220s. One has change linkages top and right, the other has them both rh side, If someone who knows could tell me if they're suitable for a 300D, I'd appreciate that. I can't quite read the numbers, but the side-linkages one has 115 (among other numbers) stamped on the case. Both appear to have cast-iron cases with Al bells.
Graham
Oops! tried to attach a photo - try again. Successful?
This post was last modified: 07-14-2014, 10:39 PM by Biocruzer.
Biocruzer
Graham
EmJay
07-14-2014, 10:43 PM #7
A buddy of mine did a motor swap into a 93 Mazda B2600i, using an OM 617 and the manual transmission from the truck. He used the trucks and made an adapter plate, then had a machine shop mate the two flywheels. It weighed well over 50lbs but it ran reliably.
EmJay
hooblah
07-21-2014, 04:49 PM #8
I have a 5 speed from a 190d 2.5 NA if anyones interested?
hooblah
07-21-2014, 05:40 PM #9
(07-14-2014, 10:43 PM)EmJay A buddy of mine did a motor swap into a 93 Mazda B2600i, using an OM 617 and the manual transmission from the truck. He used the trucks and made an adapter plate, then had a machine shop mate the two flywheels. It weighed well over 50lbs but it ran reliably.
Diesels kinda like the heavy flywheels they absorb some of the power impulses and om617s don't really rev that fast any ways they are a better torque motor so a heavy flywheel is actually kind of a benefit. a 240d 616 4 cylinder flywheel on a 617 is to light and causes vibration issues at certain speeds.
This post was last modified: 07-21-2014, 05:42 PM by willbhere4u.
 7 Guest(s)
 7 Guest(s)
