STD Maintenance General Broken ABS sensor off, rest is still in diff.
07-23-2014, 08:40 AM #1
Suggestions?
Suggestions?
07-23-2014, 09:20 AM #2
(07-23-2014, 08:40 AM)winmutt Suggestions?
Unbolt it and pull it off?
07-23-2014, 01:57 PM #3
(07-23-2014, 09:20 AM)DeliveryValve
I mean, its physically broken. Tried pulling it off when swapping in the new one. Guess I will pull the diff and see if I can get at it on the inside.
07-23-2014, 02:17 PM #4
(07-23-2014, 01:57 PM)winmutt
Negative. There is no way you can get it from the inside without pressing out the pinion. Your just going to have to drill, screw in a lag bolt to hook it up to a slide hammer and slide hammer it out.
mario
07-23-2014, 02:33 PM #5
Put a screw into the remaining section and try and collapse the side of the remaing bit and it might come out
mario
07-24-2014, 10:22 AM #6
(07-23-2014, 02:33 PM)mario Put a screw into the remaining section and try and collapse the side of the remaing bit and it might come out
Ya, I havent been able to get a screw to hold in there yet.
07-24-2014, 11:11 AM #7
Your gonna have to post pics of this so we can see what is happening.
07-24-2014, 06:19 PM #8
Is this a stainless steel bodied sensor?
01-12-2015, 11:20 AM #9
Bicycle pump in the drain hole and blow that sucker out?
 10 Guest(s)
 10 Guest(s)
