16 valve 5 speed?
16 valve 5 speed?
i have read that the 5 speed in the 190 16v is the same trans as the 5 speed used in some bmw's would that mean that the bell bolt pattern is the same? there is a guy here selling all his bmw stuff cheap to get ride of it (he is moving across the contery) he listed at least 5 5 speed trans would they be good to bolt to a 603/606?
Similar. I think they are similar internals but the bellhousing is one piece or something like that. I looked at a number of them and came to the conclusion they wouldnt work. Also the shifter is different. Probably worth looking at again.
I can tell you the bell housing are different from the same era BMW transmissions even the M10/S14 engines. The bell housings are only removable on automatics. But the backplates are removable, I expect you could tear apart one and fit all the stuff inside the Mercedes getrag or make a bell housing adapter plate. But strait bolt on. No.
(09-15-2009, 07:11 PM)giezy i know it is 1:1 i gess i will just find a 16v trans to use instead. I was just thinking if they fit i could get the for $250.
Will a trans from a gas or smaller diesel hold up to a tweeked 603?
(09-15-2009, 11:18 PM)Kozuka the fins like autosAlmost all I've seen have been manual.
What would be the ideal manual transmission for these diesels.
Lets say the om603, and even the om617 engines.
I read kamel has a getrag 4speed on his car, what do those come off of?
Id like to know what to keep an eye out for at the junkyard.
The most sraight-forward to install, reliable stick?
