STD Tuning Engine Dodge cummins 07-08 holset turbo question
Actros617
What's a spark plug???
49
09-16-2009, 12:37 PM #1
I was wanting to know if a vgt holset turbo charger from a 07-09 dodge cummins, be able to fit into a w126 300sd engine bay I know that it's computer control but it shouldn't be hard to convert to a penumatic...
Actros617
09-16-2009, 12:45 PM #2
It will fit, but its much too large (in airflow) for a 617 to handle unless you're wanting to push 300+hp. Even the 4BT guys say its too large for their engines.
Its also 50lbs.
This post was last modified: 09-16-2009, 12:46 PM by ForcedInduction.
Its also 50lbs.
Actros617
49
09-16-2009, 12:52 PM #3
Really, even it's Vnt it would not help in spooling the turbo.
Actros617
09-16-2009, 12:57 PM #4
Its not so much getting it to spool but the huge compressor wheel flowing too much air to be useful.
Actros617
49
09-16-2009, 04:52 PM #5
Do you recommend any other Holset turbo for a OM617??? (I want to upgrade my turbo)
Actros617
09-16-2009, 06:16 PM #6
HX30, HY30, HY35, HE341 and HE341Ve. The HX/HY25 would be a little too small and the HX35 would be slow to spool.
Actros617
49
09-16-2009, 08:25 PM #7
how's the bolting pattern???? T3
This post was last modified: 09-16-2009, 08:27 PM by Actros617.
Actros617
09-16-2009, 08:57 PM #8
yes I believe they are t3 on the older Holsets! HX HY series
09-16-2009, 09:50 PM #9
Yes, all T3 except the HE351Ve.
2.5-10
Nothing Clever
67
09-17-2009, 01:24 PM #10
sorry to be off topic, any holsets use the T-25 flange?
1976 W115 medium red/tan 240D (undergoing M117 heart transplant)
1989 BMW E30 327iC SETA 5MT
1987 white/black 190D Turbo Diesel - Recaro 16V seats, Monoblocks, 11PSI.
2009 white/black C63 ///AMG
1987 BMW E30 325E M50B25NV 24V swap 5MT. 5 lug.
1999 white/grey ML430
1991 BMW E30 318i 5MT (Beater)
1990 BMW E34 525i 5MT
1997 red/black/black SL600
2.5-10
Actros617
49
09-17-2009, 02:15 PM #11
What's the diffrence between HX and HY and W at the end of model it has a W dose that means wastegated???
This post was last modified: 09-17-2009, 02:16 PM by Actros617.
Actros617
09-17-2009, 04:41 PM #12
I believe the HX vs HY has something to do with the size of the exhaust housing???
09-17-2009, 05:40 PM #13
(09-17-2009, 01:24 PM)2.5-10 sorry to be off topic, any holsets use the T-25 flange?
The HX/HY25 model does.
(09-17-2009, 02:15 PM)Actros617 What's the diffrence between HX and HY and W at the end of model it has a W dose that means wastegated???
As Will said, turbine housing size. HY has a smaller housing that will spool much quicker. W means wastegated.
 8 Guest(s)
 8 Guest(s)
