Monarch vs 315 injectors
I need to rebuild my injectors and I am not sure if I should go with the monarchs or the 315s. I have done some searching and found that the 315's flow about 15% more than the stock nozzles. I would like to go with something that makes a little more power if possible.
The monarchs have good feedback for running smooth and clean. I haven't found any feedback on anyone who has run the 315s. Right now I am leaning toward the 315s due to the additional power potential, but just want to be sure that they will run "good" and not be too smoky.
Also, anyone have a good source for the 315s, or a part number?
PM greazzer, he's the resident injector guru
Monark ..http://www.monark-automotive.com/en/products/injection-equipment/
Most likely a typo. Monark merged with DES or vice versa, but I understand the company still goes by "Monark"
Monark is the manufacturer and 315 is the original Bosch number for the nozzle. They supposedly have an improved spray pattern. Bosio is also very popular, but I am told both are better than new Bosch nozzles, which are made in India.
(09-12-2014, 09:07 PM)kahlil88 Monark is the manufacturer and 315 is the original Bosch number for the nozzle. They supposedly have an improved spray pattern. Bosio is also very popular, but I am told both are better than new Bosch nozzles, which are made in India.
Well stock nozzle number I believe is DNOSD265 or some such, the DNOSD315 nozzles have potential to flow more fuel but unless your pump is putting out more fuel there won't be much if any difference in performance.
