Long runner intake question
I am planning to upgrade my OM617a to an A/W intercooler. I have seen a few posts (ForcedInduction) that show a W115 NA long runner intake clearing the turbo, but does anyone know if the W123 NA intake will clear the stock T3 compressor housing. I noticed that the runners don't angle up as sharply as the W115 NA intake. Here is a pic of the intake that I found yesterday at the local U Pull.
https://plus.google.com/photos/113477374...4157972190
I have already turned up the MW pump, set cam timing to stock +2 degrees - inj timing is at 27 btdc, reamed the burn holes in the PCs, and installed a 60 trim compressor wheel and a stage II turbine wheel in the turbo.
(10-08-2013, 10:38 AM)MFSuper90 I'm pretty sure the NA intake won't fit over the exhaust housing
They seem to get harder and harder to find. They are a nice bolt on for people going to run a A\A intercooler. But they do pop up every once in awhile if you keep you eye open or put up a WTB
(10-08-2013, 12:37 PM)MFSuper90 They seem to get harder and harder to find. They are a nice bolt on for people going to run a A\A intercooler. But they do pop up every once in awhile if you keep you eye open or put up a WTB
Cutting and rewelding a standard turbo intake would be similar as well, just bake the oil out first.
I tried to fit a GT2056V and the NA intake-it wouldn't fit, but if the turbo was like 1/2" lower it would have.
(09-19-2014, 06:46 AM)Simpler=Better Cutting and rewelding a standard turbo intake would be similar as well, just bake the oil out first.
(10-01-2014, 07:17 AM)kestreltom(09-19-2014, 06:46 AM)Simpler=Better Cutting and rewelding a standard turbo intake would be similar as well, just bake the oil out first.
Ahh..Haa! That is what I needed. Thanks!
I have a nearly new GT2256V with the 3 bolt exhaust flange. I am planning to fab a custom T3 type flange adapter for it, so I will plan on making it so that the turbo is lowered about an inch or so. So far, I am debating whether to weld a T3 flange to the existing turbine housing, or just make an adapter. You can weld cast iron - just need to get it as hot as possible in an oven first.
