What can I do to make more power?
Got my M pump back from DieselMeken and I am looking for ways to make more power. I already have a ebay GT30R and big FMIC. Right now the max I can make is 20psi but I think its because of my super quiet restrictive exhaust...or ebay turbo. My fueling is 160cc right now and it have some black smoke out the tail pipe under boost. Is it advisable to drill out the prechambers? What about adding a degree of timing?
(09-22-2014, 08:09 PM)TurboTim Got my M pump back from DieselMeken and I am looking for ways to make more power. I already have a ebay GT30R and big FMIC. Right now the max I can make is 20psi but I think its because of my super quiet restrictive exhaust...or ebay turbo. My fueling is 160cc right now and it have some black smoke out the tail pipe under boost. Is it advisable to drill out the prechambers? What about adding a degree of timing?
Wastegate line not attached and its an OM 603. Yes exhaust is stock other then downpipe and added a flowmaster muffler instead of stock rear muffler.
(09-22-2014, 08:31 PM)TurboTim Wastegate line not attached and its an OM 603. Yes exhaust is stock other then downpipe and added a flowmaster muffler instead of stock rear muffler.
Trans isnt slipping. How much boost are you getting? Its probably this ebay turbo just isnt that great.
Check timing too
I have a blow off at 30psi for now. The wastegate is welded shut on mine, but yea my truck has a china ebay turbo on it and I dont get boost like I should, so thats probly the reason. My Benz has a good holset. And yes the timing procedure is different than stock, ususally around 20 degrees before tdc... but if its running smooth with no white smoke and has some black smoke (not too much) its probly close but check it!
Yeah I did set timing per mb spec of 15atdc but I was more on the conservative side of having that pin centered. Maybe I will make sure its centered then. I am not saying my car is slow either. It may be fast I just want to do what ever I can to make it faster being that its the slowest car in my garage.
Already got all the parts to make a full exhaust. Tried to make it during work but couldnt find the time. Should have it completed this weekend. What are people using for manifolds? Stock or are people make custom ones?
The stock cas manifolds aren't that great, but they're not horrible either. Grab a plate of steel, a sharpie, and get cutting
