STD Other FS / WTB / Buying guides where to find used parts im Germany?
NapaBavarian
09-30-2014, 01:46 AM #1
Im in Munich and will be traveling around a bit, I need w126 pedal cluster for a standard transmission, euro lights for a w126 coupe, and perhaps om601 and om603 turbo exhaust manifolds...
NapaBavarian
Whizbang
09-30-2014, 10:48 AM #2
das junkyard?
Whizbang
das junkyard?
09-30-2014, 03:29 PM #3
Look at the German W123 forum. Also, German Ebay and see if any auctions close during your time there ...
NapaBavarian
10-01-2014, 02:21 AM #4
All the usual suspects? Everything is diesel...I may just stay here
NapaBavarian
Max
Turbinaaa
87
10-01-2014, 02:54 AM #5
"Ebay-Kleinanzeigen" was always a good Source for cheap Parts.
You just have to search a little bit Wink
Greetings from Augsburg
Max
Max
Max
NapaBavarian
10-01-2014, 03:02 PM #6
Perhaps I need to come back again later?
NapaBavarian
10-01-2014, 04:04 PM #7
You need to get all the 617 flywheels and w115 intakes you can find.
