STD Other Projects Classic Sleeper 617 (85 300CD)
  • 1 Vote(s) - 5 Average
SupremeTurbo617
Somewheres around 150HP
36
10-30-2014, 07:17 PM #1
Alright guys, as someone who has been a daily browser of these forums i have finally decided to make an account and share my thoughts.
Here is what I've got:
1 - 1985 Mercedes 300CD (Turbo)
1 - Garret T3 (On its way out the door as soon as i find a HX35)
Somewheres Around 10 Quarts - Shell Rotella T6 Fully Synthetic
1 - Aftermarket Bosch Radiator
1 - Veggy Oil Conversion Kit (Disabled)
A Few Floor Jacks
And last but probably most important a decent collection of non-electric tools
What are my goals:
1: North of 300 HP (In Progress)
--1a: an 8mm Super IP (Im from the US so i would very much appreciate a stateside option and estimated price)
--1b: a HX35 Turbo
--1c: Water to Air Intercooling
--1d: No more TRAP Ox
2: Daily Driver
3: Speed
So far I have completed:
--valve adjustment,
--oil change + filter(needs another but my wallet is empty until I collect some checks),
--radiator swap,
--engine compartment degrease (it could use a second coat),
--Manual boost controller (was 6 psi MAX before not 13-14 max),
--cleaned interior,
--new primary and one new secondary fuel filter (mine has two),
--new injector return lines (in progress),
--overboost protection solenoid bypass (I'm aware this isnt ideal but I wanted to),
--swapped return and pull fuel lines (the tank sock is clogged and I was unable to remove it),
--exhaust removal (I pulled off the exhaust system past the point where it drops out of the engine bay, essentially at the first point I could without cutting it),
--new sound system control unit,
--ALDA adjustment,
--egr computer bypass (paperclip for the tach),
--alarm system disabled (worked great until I locked and unlocked my door so much that i think i broke the sensor)
So that my friends is where I am at. She is a blast to drive and i hate to admit it but i floor her at lights and love to break 80 whenever possible (55 State Speed Limits), I will be posting photos soon but i would like to pose a few "simple" questions:
--Where and for how much may i purchase a 8mm pump?
--How would i go about installing a HX35?
--Reasonable price for a HX35?
--Intercooling.......
--Thoughts on parts such as a forged crank (where), domed pistons (are they already?), heavy duty valve springs (where) and anything else you guys can dream up.
--Where can i get prebuilt and tested 315 injectors
--Where would i find a "test pipe" for the exhaust to bypass (read remove) this hunk of metal under my turbo?
Here She is:
[Image: Front%20Edited.jpg]
[Image: Front%202%20Edited.jpg]
Under the Hood
[Image: 20141104_134338.jpg]
Drivers Side View
[Image: 20141104_134353.jpg]
Passenger Side View
[Image: 20141104_134406.jpg]
For all of you who like to hear what things sound like:
This post was last modified: 11-04-2014, 05:17 PM by SupremeTurbo617.
SupremeTurbo617
A Few Floor Jacks
What are my goals:
--1b: a HX35 Turbo
2: Daily Driver
3: Speed
--valve adjustment,
--radiator swap,
--cleaned interior,
--ALDA adjustment,
Here She is:
Under the Hood
Drivers Side View
Passenger Side View
10-30-2014, 08:40 PM #2
$250 is reasonable for a used HX35. You might want to look into a hy35, as it will spool faster on the lower VE om617.
Dieselmeken was working on a set of elements for an MW pump. He can send them to the stateside shop to put them in if he has them done.
SupremeTurbo617
36
10-30-2014, 08:42 PM #3
I might have access to an H1C shortly, would that be worth my time to consider or should i just try and find a HY35 from the get-go?
Any idea on what Dieselmeken is looking for a set of 5 elements?
SupremeTurbo617
10-30-2014, 08:54 PM #4
Email or pm him. He's a busy guy, and I'm not sure he had the final design done yet or not. Hy35s are cheap and plentiful, h1C are old technology and spool slowly.
SupremeTurbo617
36
10-30-2014, 08:57 PM #5
Awesome, thank you for your two cents; looks like I'm off to craigslist for an hy35 and to send a few messages. Wonder what time it is over in Sweden...
Quick question regarding your EGR-less manifold, where did you find those block off plates? Ive been scouring the forums and cant seem to find a definitive answer on where to buy some other than "pm so and so who is no longer active." Unless of course you just found one with no egr from the factory.
SupremeTurbo617
anjay
1998 E300 Turbodiesel
57
10-31-2014, 12:53 AM #6
I have one! How badly do you want it? You can PM me and we can talk.
1987 300TD - tinker toy
1989 300TE - parts
1991 300TE - backyards decor
1991 300TD - Barrote’s 7.5
1998 ML320 - snow ride
anjay
1989 300TE - parts
10-31-2014, 08:12 AM #7
You can make egr plates by hammering a piece of copper for the round guy, and tracing the gasket for the flat guy. If you have a sawzall, file, hammer and drill you can make the blockoff plates easy. Personally I'd tap the round part, and install an exhaust pressure gauge.
Expect to pay $1500-$2k for big elements and calibration. Dieslmenken is the guru, but there is a stateside shop he works with-search for his posts they're in here somewhere. The pump is the biggest hurdle($$$$), you should get the pump then get everything else going.
Greazzer can get you bigger nozzles for the injectors
The turbo crank is already hardened, the turbo pistons are already the best design you can get. You will get gains by porting the head and making a better exhaust manifold. The N/A w115 intake is super-duper, the w123 N/A intake is great too, but takes a custom manifold to fit a turbo.
Reaming the prechambers is said to help, I've never run them but Captain America likes his Smile
There's a guy up in Canada who makes custom cams for TDIs. He would be the right person for a hot 617 cam. Search will find him.
After all that you'll need to turn up the pressure in the transmission or go manual. There's a shift kit floating around somehwere.
PM me if you need the hookup for weld-els or flanges. I'm out right now but can make more.
This post was last modified: 10-31-2014, 08:16 AM by Simpler=Better.
SupremeTurbo617
36
10-31-2014, 11:52 AM #8
So my next bets should and will be transmission shift kit then finding 2 grand for a pump. Of course i also need to see if greazzer can get me FULL 315 injectors pop tested and all, not just the nozzels. Photos will be added shortly!
SupremeTurbo617
10-31-2014, 12:35 PM #9
(10-31-2014, 11:52 AM)SupremeTurbo617 So my next bets should and will be transmission shift kit then finding 2 grand for a pump. Of course i also need to see if greazzer can get me FULL 315 injectors pop tested and all, not just the nozzels. Photos will be added shortly!
The bodies don't matter, any standard injector is fine. The nozzle is what counts
SupremeTurbo617
36
10-31-2014, 12:40 PM #10
Well my logic is that i rather they be pretested and set so i dont screw it up while installing the nozzles. Besides as my daily driver more than a few hours down time is a problem so shipping my current set out doesnt work.
SupremeTurbo617
10-31-2014, 12:52 PM #11
How soon do you want the set of 315s? I have a set with only a few thousand miles on them
SupremeTurbo617
36
11-04-2014, 04:53 PM #12
So i messed around a little bit today and finalized some of the EGR removal and pulled out the vac lines to and from the valves and cleaned it up a little bit. I managed to break 2 of the hard lines for the ALDA banjo bolts, luckly within an inch of each end but they were a bear to get reinserted into the hard lines.
[Image: 20141104_152414.jpg]
SupremeTurbo617
SupremeTurbo617
36
11-04-2014, 08:22 PM #13
So ive got a few of those really tough to pin down questions.
1: What is the best rear end i can get ratio wise and hopefully fully locked?
2: Six Speeds. Is the 420G still the best i can do reasonably?
3: For my current transmission is it alright to run Dex VI? its a stock 4 speed and i feel i might get slightly better reaction times out of it with a fully synthetic.
Thats all for now, im working on 315 injectors and a 8mm pump from that place in california. well to clarify im working on the money. I might throw a HY35 into the mix somewheres along the line.
SupremeTurbo617
11-05-2014, 09:56 AM #14
For now, the best thing you can do to your transmission is turn up the modulator on the side of the trans to get more line pressure out of it.
And what the hell is all that trash in your engine bay? Huh
Those trap ox manifold are goofy looking. I've got a spare turbo manifold i could cut up and make it non EGR for you, and I've also got a stock turbo manifold if you decide to go a different way than A/W.
This post was last modified: 11-05-2014, 10:01 AM by MFSuper90.
11-05-2014, 10:35 AM #15
It's a waste oil system, I used to run the same switchover valves(they're cheap&common)
SupremeTurbo617
36
11-05-2014, 03:46 PM #16
Simpler=Better is spot on about the mess. As it stands i am thinking of pulling out that system and selling it.
SupremeTurbo617
mbz123
11-05-2014, 04:02 PM #17
Always love when mr. v. grips can drop in for a photo op 8-D
my sides = in orbit
They make $$$$ hose clamps, tho, when they manage to come loose!
MBZ123
mbz123
my sides = in orbit
MBZ123
SupremeTurbo617
36
11-05-2014, 04:04 PM #18
(11-05-2014, 04:02 PM)mbz123 Always love when mr. v. grips can drop in for a photo op 8-D
my sides = in orbit
MBZ123
And on the eighth day god created vicegrips!
This post was last modified: 11-05-2014, 04:13 PM by SupremeTurbo617.
SupremeTurbo617
my sides = in orbit
MBZ123
SupremeTurbo617
36
11-06-2014, 04:27 PM #19
Slight Update Today. I had having some trouble with my transmission having a long (i mean like 5 to 10 second long) drawn out shift from 2nd to 3rd. At first i assumed it was just mercedes trying to avoid a harsh shift (dont judge i wasnt thinking straight) and ignored it. Then i thought ok this is a bit long and can not be healthy. So i checked my tranny fluid and found it has no odor to it and that the level is mostly consistant. (It leaks around the pan a little bit, not enough to drip but its wet) Then i opened a forum question here in the drivetrain subgroup about what transmission to swap in and asked a few more leading questions. Somehow it came to my attention that i should adjust the vac modulator for the tranny. I then jacked up the car and looked for it on the side of the case. Found nothing and went a little bit nuts until i remembered that ive got the vacuum hell model (85 Cali) and that the modulator was in the engine compartment. So i popped the hood and look a look. All of my lines were connected. And i had long ago removed the dashpot to give my shifts some strength which helped at the time. Then i traced the lines looking for cracks and punched myself in the face for stupidity. Can anyone guess what i did?
On the top of the 85 modulator it is labeled with one recessed nipple for vac and the other to the transmission. Beneath it is the pressure nipple and the turbo input pressure because in 85 they decided that instead of just vac and throttle position based it should take into account boost which will actively change based on temp, fuel, and other driving factors. Basically the holy grail in regards to telling the transmission how hard to shift and when. So it would appear that when i was trying to get my car to shut off a few months back (connection on the back of the IP that i cant see because of my grease car system) i was swapping lines and trying to get something to happen. Well when i got it working and tried to put it back to a better version of stock i swapped the vac and tranny lines on the top of the modulator. So i swapped them back and went for a test drive. The shifts are still bad but at least they are a lot faster. 2-3 is now decent. I could use a shift kit (superior) but i rather not buy a kit then pull the trans for a 5 or 6 speed a few months later.
SupremeTurbo617
SupremeTurbo617
36
11-09-2014, 07:09 PM #20
Thinking of going from my stock rear end to a 3.07 LSD rear end. Has anyone here done this and what would my advantages be? I'm figuring a better off the line and acceleration but a lessor top end speed. Heck, maybe i can finally break the rear wheels free for a nice squeal.
SupremeTurbo617
SupremeTurbo617
36
11-10-2014, 08:34 PM #21
Hey guys, new development today. Whilst i was eh hem testing the top end power and speed i ran into this odd issue where i can rev up past 80 mph but dont seem to accelerate, i am near full boost at this point but unless im on perfectly straight ground or going down hill i cant break much past 80. Its been awhile since ive hit 95 and its beginning to get disappointing that i cant seem to go any faster even with my foot to the floor. Has anyone else run into this? What should i check or do to fix this?
SupremeTurbo617
11-11-2014, 12:48 AM #22
Probably getting near the cutoff point for your IP. Adjustments will fix that problem Wink
Petar
7.5mm M pump
459
11-11-2014, 11:30 AM #23
80 mph ?? That's like 130 KM/h ??? That's way too low, a stock 240D will easily go faster than that.
You say that the engine revs up but you don't accelerate ? If that's the case the transmission is probably slipping.
Petar
SupremeTurbo617
36
11-11-2014, 11:39 AM #24
You see that is my concern. I know the transmission is going to crap but she flys from 0 to 60 then isnt too bad from 60 to 80 then it just becomes a pain to get any faster. I used to be able to hit damn near a hundred before i felt it seem to top out. I might pull my fuel filter today and see if that is clogged up. It could also be the switch over valve setup i have for veggy oil. Ive never checked that to see if it flows well. I really should pull that out and plug the input lines from the back today... Actually let me go do that and see if i cant get some results.
SupremeTurbo617
SupremeTurbo617
36
11-11-2014, 04:00 PM #25
So i pulled out my veggy oil system so she is now officially stock fuel system wise. I removed a secondary filter that was not needed (i already had one inline just up stream.) It looked something like this:
[Image: 20141111_151940.jpg]
Before:
[Image: 20141111_122903.jpg]
During:
[Image: 20141111_132413.jpg]
After some clean up:
[Image: 20141111_145621.jpg]
My results were sadly lacking. I seemed to gain no power though it does return to idle a bit quicker - go figure that one out.
This post was last modified: 11-11-2014, 04:00 PM by SupremeTurbo617.
SupremeTurbo617
Before:
During:
11-11-2014, 09:06 PM #26
That wrapped filter heater coil is worth $$ to the right person
SupremeTurbo617
36
11-11-2014, 09:15 PM #27
Don't i know it. The full kit not including the tank was 3 grand. So if anyone is looking for a full kit at a used price let me know. (Im not looking for anywheres as insane of a price as 3 grand, probably more like 5-600 for the whole thing. Tank heater lines and valves and gauges and switches included.)
SupremeTurbo617
SupremeTurbo617
36
11-19-2014, 08:06 AM #28
Well guys i have some bad news. My morning commute ended with barely arriving in the parking lot. At first i thought i was out of fuel and i probably am, however i popped the hood and found something horrifying. The small ring of oil that had been present on the valve cover gasket since i did the valves has been slowly leaking more and more. Well now i see that it has been making its way down the engine completely. Not enough to lose me oil pressure, raise my temp, or anything like that. I dont think i have even lost a quart but all the same it has now reached the point where i ordered a new gasket. More over i think my issue is a lack of fuel. So i will be phoning a friend to drop by my house and grab a tank of diesel that i pulled out since its so damned cold and i did not want it to freeze... Figures. I really should buy a new tank sensor or whatever we call it. (I would guess a sending unit).
Fingers crossed that it is the valve cover and not a pinhole in the head...
SupremeTurbo617
w123love
Stockish
354
11-19-2014, 09:15 AM #29
Seating the valve gasket is a tedious process. Don't be too hard on yourself. The fuel tank sender is most likely fouled from the WVO. I had the same issue when I ran it for a while. I had to change the sender, and the tank filter. You should get more fuel that point. There is hope for cleaning the sender if it is working even slightly. As long as you are getting some kind of reading you should be able to clean it up.
The VEGEWGN
w123love
The VEGEWGN
SupremeTurbo617
36
11-19-2014, 10:03 AM #30
I ran a seperate tank wvo system, so it wasnt that. My sending unit was just coated in the sludge that my additives ripped off of the tank walls. I then pulled it and cleaned it up but i snapped one of the lines so its broken atm. As per the strainer i could not remove it so im going to pull the tank this summer, until then i swapped the return and pull lines. I will have a gasket in my hands this evening. Any tips for seating it? I dont like seeing its lifeblood pour onto the ground
SupremeTurbo617
SupremeTurbo617
36
11-19-2014, 06:20 PM #31
Great news!! I filled her up on fuel and she sounds better than ever. I will be pulling off my valve cover this evening to see what the hell happened to the gasket. Before i do however i will be browseing the forums to see what i should have done to the gasket that i must have not done before. Let me know if you want photos of under the valve cover.
SupremeTurbo617
SupremeTurbo617
36
12-01-2014, 04:01 PM #32
So i replaced the valve cover gasket and it was great for a few days. Now i have oil leaking from around the breather on the top of the valve cover and one spot on the gasket; and i do not mean leaking, i mean a low volume high pressure style leak as there are thin arterial lines that reach a good 8 inches away. So i'm led to believe that my oil pressure is high or my crankcase pressure is high. either way i am slightly concerned. Advice is greatly appreciated.
SupremeTurbo617
raidaru
12-02-2014, 09:28 AM #33
(12-01-2014, 04:01 PM)SupremeTurbo617 So i replaced the valve cover gasket and it was great for a few days. Now i have oil leaking from around the breather on the top of the valve cover and one spot on the gasket; and i do not mean leaking, i mean a low volume high pressure style leak as there are thin arterial lines that reach a good 8 inches away. So i'm led to believe that my oil pressure is high or my crankcase pressure is high. either way i am slightly concerned. Advice is greatly appreciated.
there is some special sealant used for hg's, remove the vc, clean very well everything, and add some sealant too. The breather on the vc leak is very common to many cars, maybe some new o-rings or whatever is sealing that part should do the trick,otherwise some sealant in there too. Don't forget to let the sealant harden enough before u start the engine! GL!
raidaru
SupremeTurbo617
36
12-03-2014, 12:25 PM #34
Well you see, i have already sealed it up tight with some of the older, more quality sealant. Its as tight as it will get. My issue is that i have enough pressure present to make it spray oil at such a high velocity that it break though my well tightened and sealed breather.
SupremeTurbo617
Torkey
Dirty Diesel
220
12-03-2014, 02:14 PM #35
You might have already checked this. Maybe the oil seperator in the air cleaner is clogged.
Crankcase pressure can be very bad since it can blow front and rear main seals out.
I would treat the oil leakage around the valve cover as a symptom, not the problem.
79 300CD
82 300SD
Dirty Little Freaks Racing
Torkey
79 300CD
82 300SD
SupremeTurbo617
36
12-03-2014, 03:19 PM #36
My air cleaner does not have a seperator that i have found. It just kind of drips into the bottom of the housing for the filter. What do you think the problem is arising from?
SupremeTurbo617
Torkey
Dirty Diesel
220
12-03-2014, 04:08 PM #37
The picture below shows what I'm talking about. There is a contraption in the air cleaner that separates the oil from the crankcase gasses. That might be clogged. There are a lot of ways to test for crankcase pressure.
You can start the engine and remove the oil dipstick then put your thumb over that opening. You will feel the pressure on your thumb if it is there.
Another test is to completely lossen oil fill cap while the engine is running and see if it will stay in place. If it dances wildly you probably have crankcase pressure.
The stock oil separator always induces some crankcase pressure. A lot of us have gone to an oil catch can to completely eliminate it.
79 300CD
82 300SD
Torkey
79 300CD
82 300SD
SupremeTurbo617
36
12-03-2014, 05:51 PM #38
That line leads to nothing inside the air filter housing. It drops straight down to the bottom. I will test for pressure at the dipstick tomorrow when it is not pitch black and 20 deg. Thanks for your help!
SupremeTurbo617
SupremeTurbo617
36
12-06-2014, 09:35 AM #39
Small update on a few things. First and formost the pressure. If i were to remove the oil fill cap at idle it will hop up and down a fair bit and then oil will begin to splatter from around it. At the dipstick there is no pressure. To be perfectly honest im really starting to hope and think that it is the oil system as a whole that has too much pressure. The lower oil cooler line leaks oil when its running as well. Im probably going to go buy some more oil today and change it as ive reached the point in time where it should be done in my book.
In other news i had to, uh, test the brakes, recently. And have discovered that since then my front end is making a bit of noise; not to mention that despite my brake pads being decent their ability to stop quickly and lock up the wheels is sadly lacking. I either warped a spring or shock or tore up a balljoint. On the bright side it drives alright and i have a set of Lemförder balljoints set aside for when i figure out how to remove the old ones and reinsall them. It figures just as i decide that i will keep it almost stock and my daily driver, perhaps even selling it after i build myself another car, that something happens and i need to put more work into it...
This post was last modified: 12-06-2014, 09:35 AM by SupremeTurbo617.
SupremeTurbo617
300SD_KY
super turbo diesel
121
12-16-2014, 01:43 PM #40
I've got one of Dieselmeken's Superpumps.
Never mounted, always in the original box and packing with paperwork.
Let me know if you are interested.
300SD_KY
Hercules
12-16-2014, 04:32 PM #41
(12-03-2014, 05:51 PM)SupremeTurbo617 That line leads to nothing inside the air filter housing. It drops straight down to the bottom. I will test for pressure at the dipstick tomorrow when it is not pitch black and 20 deg. Thanks for your help!
If there is a great amount of engine blowby, crankcase pressure will push out oil at higher engine speeds. If so make vent to turbo more direct, or restrict vent line at air filter. This allows turbo to help pull vent gases out .
Hercules
SupremeTurbo617
36
12-16-2014, 04:52 PM #42
Great idea Hercules!! I will be trying that asap.
Small update guys, i recently had a bit of a love tap with a guard rail. The rail liked it rough and it ripped up my front right tire and destroyed my right fender and a bit of the passenger door to boot.
Also i have made the decision that i am going to be keeping the car fairly stock. Then i will be selling out and building a 70 chevelle.
Sorry to disappoint guys but i think this Mercedes project is a bit much for me at this point in time. The lack of parts for my car is somewhat bothersome and disconcerting should anything happen on the side of the road.
SupremeTurbo617
 18 Guest(s)
 18 Guest(s)
