STD Tuning Drivetrain GS6-53 ZF Gearbox > OM606 Adapter
Pages (2): Previous 1 2
DanielK
Big Plans, No Clue
98
09-19-2014, 06:49 AM #51
Machine it out just a little bit. Cut an insert band slightly larger than it needs to be. deep freeze the ring, press it in.
[Image: FalkonSig.png]
DanielK
fcp
10-31-2014, 07:22 AM #52
So we have some progress!
Flywheel has been completed. Dimensions checked with it fitted and I think we are all good Smile It now needs to go for balancing.
[Image: 15649220066_82d8f2ceee_b.jpg]
[Image: 15487552858_bbd1f54edb_b.jpg]
[Image: 15674536812_2691cae3d9_b.jpg]
Couple of small errors fixed. One mine - recess too big was solved with ring as per earlier suggestions (machined to 0.05mm and then frozen to get it in - thanks for the advice again guys!). The other was the machine shop that drilled the bolt holes (my bridgeport is out of action), they screwed up and drilled 2 at the wrong spacing (even professionals get it wrong of course!).. also fixed with a plug in each and I think a good save.
"Moderation is a fatal thing. Nothing succeeds like excess." Oscar Wilde
fcp
10-31-2014, 09:51 AM #53
(10-31-2014, 07:22 AM)fcp So we have some progress!
Sweet! Don't sweat the bolt patterns, I just drilled a flywheel to 12x130mm instead of 12x103mm. I'll just call it light weight as it has 31 holes in it now Tongue
axel606
11-01-2014, 04:41 PM #54
ben this has been a marathon.
well done!
i cannot wait to see this G wagen fly with this amazing drivetrain.
great engineering / great recovery from your mini - dramas.
axel606
well done!
fcp
11-03-2014, 07:39 PM #55
(11-01-2014, 04:41 PM)axel606 ben this has been a marathon.
well done!
Its been fun too Smile
I certainly learned a couple of lessons:
1) most-anyone can work in 10th of mm with care, but working to 100ths separates the engineer from the tinkerer!
2) Verniers are called 'very-nears' by the professionals for good reason when 1)
3) Carbide tooling rocks and WNMG inserts do 90% of most operations I needed to do
4) I know what I'd do differently next time around. My W123 estate could be epic with another of these .. maybe with a HE351VE and controler from Ole .
5) Spending every night 20 miles away in your workshop is a real test of you wife's patience and the very foundations of your marriage (both remarkable Smile - I won't test it with 4) anytime soon.
More updates to follow!
fcp
well done!
mbz123
11-05-2014, 04:23 PM #56
(11-03-2014, 07:39 PM)fcp
well done!
+1
My vote for best post of, at least, today. And one for best thread of the year, it has a certain "sticky" feel to it;-D
I figure you're either a professor or a philosopher because your machining skills are obviously "lacking."
Congrats and YES please keep feeding the monster. It isn't capable of synthesizing pics on its own...
MBZ123
mbz123
well done!
+1
MBZ123
fcp
11-27-2014, 05:52 PM #57
sorry for lack of posts guys, just work keeping me away from it!
I have pistons being coated ATM though, will post back on a new thread to show the results.
I'll be back on this once everything has been balanced in a couple of weeks.
fcp
USMCRAIDER
08-06-2017, 09:43 PM #58
Wow this is awesome progress!
USMCRAIDER
02-22-2018, 02:24 PM #59
How'd it all go?
How'd it all go?
 11 Guest(s)
 11 Guest(s)
