STD Tuning Engine om603 6mm pump + 3ld holset turbo
PedroFerreira
11-17-2014, 02:33 PM #1
hey someone know something about that turbo? i whant reach 230 hp whith 6mm pump, holset 3ld and intercoller..is that a possible numbers?
PedroFerreira
11-18-2014, 03:38 PM #2
hy there,
I have done a 605 N/A conversion to TD, along the way made some changes and i have now much more power than my wife´s C270.
Cylinder head is fitted with turbo valves, intake cam is from N/A , exaust is the same. head runners are polished and flow was made better ,(wich is dificult to do it better than it is).
IP is a PES M fitted with 6 mm delivering 90CC, the 6mm elements are almost at max fuel. injectors are set a 155BAR and prechambers at 1.5mm and 2.5 mm holes.
turbo is a gt 2359v curently delivering 2 to 2.5BAR, intercooler is from a w203, no so small 20x70x8. exaust pipe 65mm all the way no restriction.
unfortunatly my pump has max idle at around 4500RPM. still working with the governor to remove RPM limit.
well this mods in your engine may achive that nr u´re after. consider two gt20 instead of that holset.
regards
hy there,
regards
bruno_pinho
11-18-2014, 04:42 PM #3
Barrote,why the injectors 155 bar?
bruno_pinho
rafael cotrim
Holset hx55 eaton90
22
11-18-2014, 05:49 PM #4
Tópico dos tugas... (topic of Portuguese)
Pedro forget it, you need a big Turbo and bigger elements to show who is the boss!!
Now without jokes we all need bigger elements here in Portugal.
If it don`t blow smoke , it must be broke ! W201-Angel
rafael cotrim
bruno_pinho
11-19-2014, 05:35 AM #5
Pedro will apply some elements of 6mm that I had here was home, will ever get better ...
bruno_pinho
11-19-2014, 02:03 PM #6
(11-18-2014, 04:42 PM)bruno_pinho Barrote,why the injectors 155 bar?
hy there,
yep the injectors seem to work better at 150BAR, i´ve done 155 due to loss after some time. they do fine with the prechambers opened.
dont have experience with the 602. precups and injectors are diff.
by the way 6mm elements will give u around 100cc, maybe a bit more but that will depend on your pump governor. in mine is the limit at the moment. dont expect more than 110cc, and of course the injection time is too much. in my opinion wont do any good.
i want to go 7.5, if anyone want the same maybe we can order toguether.
hy there,
rafael cotrim
Holset hx55 eaton90
22
11-19-2014, 03:09 PM #7
Hy , i want 8 but unfortunately we have to import them...
So it depends how much they cost because i need to find a pump of om603 turbo and then swap the elements.
but if they are too expensive i buy a super pump
rafael cotrim
11-20-2014, 02:33 PM #8
the man called dieselmeken, sell them at 60€ each, i´ve been emailing him and i believe we can have them sent here.
PM me for further details.
watts wrong with your actual pump so that u need a 603 turbo?
rafael cotrim
Holset hx55 eaton90
22
11-20-2014, 04:18 PM #9
om606 has electronic pump...
I read somewhere that even with bigger elements the pump will not be able to do insane RPMs ...
rafael cotrim
bruno_pinho
11-20-2014, 04:29 PM #10
this is not true, I have 7mm elements in electric pump and do 5500rpm ...
and the maximum power is same in 5500, so it will not cut fuel before
This post was last modified: 11-20-2014, 04:35 PM by bruno_pinho.
bruno_pinho
11-20-2014, 04:53 PM #11
bolas pá , as bombas elétrica funcionam com mapas. fazes um remap e podes ter MAX FUEL as 8k Rpm.
alias, essa bomba EDC, funciona com mapas e não com software. há ai pessoal que sabe mexer nisso, eu não por enquanto.....
no entanto a alteração dos elementos requer uma alteração do MAF (engana-lo) , mesmo sem alteração do mapa.
Sorry fine people, by birth is my birth,
EDC pumps and bigger elements Sad,
regards
regards
rafael cotrim
Holset hx55 eaton90
22
11-21-2014, 02:37 AM #12
Tudo ok , mas o meu carro é um w201... E para usar a bomba eléctrica ia precisar de um carro dador para a cablagem e ia ser uma grande confusão de fios. Assim vou para uma manual que torna tudo mais simples e rápido de construir
All ok, but my car is a w201 ... And to use electric pump I would need a donnor car. besides that wiring it would be a mess.
rafael cotrim
11-21-2014, 03:28 AM #13
ok i got it , now i got it , is bruno who have the 202. mine is 124 so is prety much the same as 201. i made it to work with the N/A pump, maybe will be better than the turbo pump. lets see in the future.
regrds.
regrds.
starynovy
11-21-2014, 06:35 AM #14
So you have bigger elements in EDC pump without modding software? Does it work good? I heard it will hunt for idle as it pumps so much fuel that pump cannot reach desired rpms on idle, it hunts.
starynovy
bruno_pinho
11-21-2014, 08:38 AM #15
(11-21-2014, 06:35 AM)starynovy So you have bigger elements in EDC pump without modding software? Does it work good? I heard it will hunt for idle as it pumps so much fuel that pump cannot reach desired rpms on idle, it hunts.
No, I have a new map in the ecu ...
bruno_pinho
