The notorious BMW 316i
Hi guys. Some of you know and some don't. We have been building a pretty hairy BMW 316i Compact for a while.
The car is a e36 BMW but with a full front, lights and hood from a M-style e46.
Engine wise it has a om605 with tougher valve springs, n/a cams and a Dieselmeken 8mm 242cc IP.
ZF BMW 325tds gearbox (the third because we actually trashed two in 200m and 5min of driving), single mass flywheel, Sachs 765 PP and a 6-point sinter clutch.
BMW 5-series differential with a stock LSD.
Turbo is a ITS ballbearing turbo witch is to small and the ASS-dyno says around 500whp. No need for a propper dyno untill the turbo is replaced and we can do some serious power.
I will post pictures in a moment!!!
Sorry. Thank you for sharing. I hope your man is better than new soon.
Omg all that hard work and fabbing. Atleast he survived! And probly the engine did too
Wow, good he survived! Was this on the public or closed road?
Thanks guys! The engine is fine and the driver will be ok. He's a leftie so having a hard time right now with all his injuries on the left side. The intern was in the car with him but got no injuries what so ever and back in the shop today (I gave him a day off )
The engine and trans will go in to a 1972 BMW e3 3.0s will be an awesome sleeper.
Thanks guys. The w202 is actually making progress so who knows, there might be a first start up soon
The quad had to work hard today moving the trashed BMW. But now the shop lookes ok again.
Mr Fabricator is home and doing as fine as possible with a lot of broken ribs. Bad thing is that we can't make any manifolds in a while and that's our main business
The accident was on the public road but no other car was involved or even close. Even I thought it was a stupid misstake but the differential might actually be damaged, will check in to that.
