STD Tuning Engine W124 OM602 gas problem
Keino
11-22-2014, 10:43 AM #1
Hi!
Having a problem with om602 stock engine. W124 -91
When the engine is cold it runs as it should, when temp is @ 90c (warm engine) it starts acting a bit "funny"
When giving gas with the pedal it does not respond until halfway down, and just before you get the response there is this nasty knocking sound, engine is powerless and does not revv up, and if giving some more gas it is like the gear kicks in and it starts accelerating again.
Happens if i try to keep the engine around 2000rpm.
Also if giving very little gas it jerks back and forth until you floor the pedal.
I suspect there is something wrong with the fuelinjection.
What do you guys think? Ideas?
And! It smells like shit everytime the car has been running and I get out of it. Smells like burnt plastic or something like that. HuhHuh
Keino
Hi!
11-22-2014, 02:12 PM #2
(11-22-2014, 10:43 AM)Keino Hi!
IP governor masses giving up, or timing advance sprocket , damaged.
does the engine smoke white when hot?
Keino
11-22-2014, 02:58 PM #3
(11-22-2014, 02:12 PM)barrote
No no smoke at all Undecided
Keino
Petar
7.5mm M pump
459
11-22-2014, 04:45 PM #4
Does it have EGR ??? If so try blocking it.
Petar
Keino
11-22-2014, 04:53 PM #5
(11-22-2014, 04:45 PM)Petar Does it have EGR ??? If so try blocking it.
Yes it has egr.
You think that would help?
Keino
Yes it has egr.
Petar
7.5mm M pump
459
11-22-2014, 05:06 PM #6
Maybe. You have nothing to lose by trying. Although i think it would blow thick black smoke if it was stuck open.
Petar
Keino
11-22-2014, 05:09 PM #7
(11-22-2014, 05:06 PM)Petar Maybe. You have nothing to lose by trying. Although i think it would blow thick black smoke if it was stuck open.
Engine blows some smoke if revving it on idle. Pump has not been touched as far as i know.
Keino
11-22-2014, 05:12 PM #8
well, check EGR system. block it. it worth F nothing.
smoke idling, hum how much? and when hot?
Keino
11-22-2014, 05:29 PM #9
(11-22-2014, 05:12 PM)barrote well, check EGR system. block it. it worth F nothing.
I'll check smoke tomorrow give u a a better idea of it.
What is the best way of blocking the EGR?
Keino
11-22-2014, 05:44 PM #10
take a hammer find a 50 cent euro coin, smash the coin til u can thin it enough to close the port at the exaust manifold.
Big Grin
Big Grin
Petar
7.5mm M pump
459
11-22-2014, 05:49 PM #11
If it is not EGR related you could try swapping your injection pump with a known good used one.See if the behavior changes.
Hopefully it is not an internal engine problem...
This post was last modified: 11-22-2014, 05:50 PM by Petar.
Petar
Keino
11-23-2014, 07:33 AM #12
(11-22-2014, 05:49 PM)Petar If it is not EGR related you could try swapping your injection pump with a known good used one.See if the behavior changes.
I hope the IP is ok... And ofcourse I dont have another pump to swap. Otherwise that is a good idea.
Maybe I'll have to get one
Keino
 11 Guest(s)
 11 Guest(s)
