300SDL turbo upgrade to 350SD
I need to get a new turbo so I'm going to get the 350SD turbo and exhaust manifold. I'm going to have James @ Performance Techniques rebuild and put a 60 trim in it.
Will this setup work with my stock 300SDL injection pump and not frag the engine? I have not modified it. I did remove the alda, egr, and smog stuff under the airbox. I know without the alda I have no overboost protection. I'm more concerned about running too lean.
(12-08-2014, 05:54 PM)natew I need to get a new turbo so I'm going to get the 350SD turbo and exhaust manifold. I'm going to have James @ Performance Techniques rebuild and put a 60 trim in it.Yes, it can't harm the engine. Although it may have a bit more turbo lag.
Quote: I have not modified it. I did remove the alda, egr, and smog stuff under the airbox. I know without the alda I have no overboost protection. I'm more concerned about running too lean.First things first FORGET everything you know about gassers and their air fuel ratios.
