Another OM603 to OM606
I thought I would share my progress as the initial startup draws close. You know what they say, a picture is worth a thousand words:
Here is a "body shot" from almost 2yrs ago:
Yes, that is a 603 pump but it has 606 guts. I am still undecided about wastegate control but the pump was configured with my modest goals. I didn't want a larger pump as this is being configured for light towing capacity, I do not need big power just reliable >300ft-lbs will make me happy.
I do also have a very fast C32 fs currently in NC headed back to FL once the wagon is done. Peddling it off for bike money now that I can do so many great rides in 4hrs or less. If I still have the C32 here in the spring I might do one more SRT Dragon run if any of you own/lurk there too.
I'll try to answer questions but I wont be doing a full build thread...
(11-11-2014, 08:01 AM)Hario Murder black looks sweet.
Still need's converted to boost actuator, and boost controller as per others guides.
Need to plumb in the overflow.
ARGH Linkages why...
Your wagon is badass!! Did you do the paint? What's the finish called on your wheels?
I want to copycat on my W123 wagon &/or Impreza wagon!
Does it have SLS suspension?
Keep it up!
(12-02-2014, 09:38 AM)CRD4x4 Your wagon is badass!! Did you do the paint? What's the finish called on your wheels?
Keep it up!
Keep it up!
exhaust is connected, linkages are "working" but not finished and I'm told it has great power considering no boost. Now to get the IC plumbing done and start logging miles.
Ha, I can finally get rid of the funnel I have been feeding the transmission with for 4 years!
