Compound turbo G
Compound turbo G
Specs:
om606 compound twin turbo
722.6 gearbox
8mm herlevi pump
Not dynoed yet but goes 5.85s 0-100kmh with 2250kg curb weight:
https://m.youtube.com/watch?v=z7pc23S032w
There: http://1drv.ms/1xgfNcQ is couple pictures along the way. After tohose pictures other wategate has been changed to turbosmart and bigger turbo is now hx50.
Need some work for high rpm but low rpm is now is good:
Dyno sheet
http://1drv.ms/1yuGZak
(10-17-2014, 11:31 AM)JSJFIN Specs:
722.6 gearbox
8mm herlevi pump
722.6 gearbox
8mm herlevi pump
(01-19-2015, 06:34 PM)seanyt Looks like
R4449-2 HP
R6164-5 LP
Turbos, I just bought a t3 .42/.48 similar size to the r4449 so I can go compound this summer.
Dyno results are crazy. What boost do you run?
R4449-2 HP
R6164-5 LP
(01-21-2015, 11:40 AM)seanyt Lovely work,
Do you think that log style manifold was giving you all that back pressure or do you think the hx50 will help with that now?
(01-26-2015, 08:47 PM)Mr_Robs Looks awesome!! You dont see too many compound turbo setups!
What specific 722.6 do you use? Just curious what model it came out of because im planning to use an E55 box but swap the W210 OM606 bellhousing onto the front.
(01-28-2015, 07:13 AM)JSJFIN(01-26-2015, 08:47 PM)Mr_Robs Looks awesome!! You dont see too many compound turbo setups!
Now there is w5a580 but i was lucky to find CL65 AMG (w5a900) box in ebay just last week. I have to change bellhousing too but it should be easy operation.
(01-28-2015, 02:46 PM)Mr_Robs(01-28-2015, 07:13 AM)JSJFIN(01-26-2015, 08:47 PM)Mr_Robs Looks awesome!! You dont see too many compound turbo setups!
Thats awesome! No issue holding the current torque and power with the current w5a580? I assume you are picking up the w5a900 because you want to have more power in the future
