STD Tuning Engine Mechanical tappets
Mechanical tappets
Mechanical tappets
bruno_pinho
12-19-2014, 12:20 PM #1
HI
Do you know if there is mechanical valve lifters for om605 / 06?
bruno_pinho
HI
AlanMcR
mind - blown
400
12-19-2014, 02:00 PM #2
(12-19-2014, 12:20 PM)bruno_pinho HI
Given the design of the head, that would be very unlikely.
Why would you want mechanical lifters?
AlanMcR
12-19-2014, 02:12 PM #3
Hello,
i dont remember any reason why someone would do that in a MB head, maybe a valve and Springs upgrade, but why not.
i know a place where they do that, usually they cut the bed to install shim type valve lifters. interesting in the MB head is that we have a separate bed from the head for lifters Smile
Hello,
bruno_pinho
12-19-2014, 02:22 PM #4
(12-19-2014, 02:00 PM)AlanMcR
Applied a turbo gt2559v in my om605 and I have a problem I can not explain it well, but I think the problem comes from the lifters
bruno_pinho
12-19-2014, 02:49 PM #5
You are sure you are not drawing too much oil from the cylinder heads's supply semehow? Or have blown the headgasket now?? Usually the hydraulic lifters are free of trouble. If not broken (which can happen - they don't hold pressure and start to rattle).
However I see no reason why it would not be possible to add solid lifters with shims to this engine - it was very common technology for a long time... But i believe you would be curing a symptom, not an illness with solid lifters Smile
This post was last modified: 12-19-2014, 02:49 PM by DiseaselWeasel.
'88 300CD Turbo Coupé - OM603
DiseaselWeasel
Eric78
12-19-2014, 05:47 PM #6
Properly functioning hydrauling lifters are almost always an improvement on solid ones.
Eric78
bruno_pinho
12-19-2014, 07:11 PM #7
I can not explain in English what happens ..
Tomorrow I will try to make a video ...
bruno_pinho
