STD Tuning Engine Om60x bellhousing pattern
Eric78
12-19-2014, 04:08 AM #1
Just wondering, is the bellhousing bolt pattern of the OM60x engines unique to diesel engines or is it shared with some petrol engines? I ask because I have a trans from an AMG 55 & to the eye it appears that it would bolt up to my OM605 with only one unused bolt hole near the starter.
Eric78
Druk
12-19-2014, 04:13 AM #2
Manual 717 box from a 320E M104 petrol bolts straight to a 606.962 diesel.
Bolt holes all line up with no extra or missing holes.
This post was last modified: 12-19-2014, 04:14 AM by Druk.
Druk
12-19-2014, 08:30 AM #3
V8, V6 pattern is different.
TurboTim
12-19-2014, 08:52 AM #4
Different. You can swap bell housings with another in line transmission of the 722.6 variety. I just did this and it wasn't to bad to do. The pump has to come out and some of the clutch packs but not bad at all. I got a trans from a c230 and it was only $180. Not a bad price for a whole transmisssion.
76 300TD custom lots of stuff
TurboTim
Grecy
12-19-2014, 02:58 PM #5
(12-19-2014, 08:52 AM)TurboTim Different. You can swap bell housings with another in line transmission of the 722.6 variety. I just did this and it wasn't to bad to do. The pump has to come out and some of the clutch packs but not bad at all. I got a trans from a c230 and it was only $180. Not a bad price for a whole transmisssion.
I thought those transmissions had an integral bell housing?
-Dan
Grecy
-Dan
12-19-2014, 05:03 PM #6
inline engines gas or diesel share same patern, v engines share same patern usually gas but now there are diesels as well.
some autos are the same in the gears stage.
Eric78
12-19-2014, 05:44 PM #7
If it doesn't fit then I think an adapter plate is a better option for me, very few 722.6s are available in Aus & they are expensive, & it would cost too much to get a bellhousing & clutch drum sent here.
(12-19-2014, 02:58 PM)Grecy
-Dan
Yes & no, it can be removed from the main case but K1 clutch drum & the pump are attached to it.
This post was last modified: 12-19-2014, 05:45 PM by Eric78.
Eric78
-Dan
Eric78
01-09-2015, 01:33 AM #8
Well this is an anomaly, The trans is definitely a WA580 722.636 but I've made a template of the bellhousing & the bolt holes all line up with my 605 which is an odd stroke of luck considering the 636 is supposed to be behind the M113
Eric78
erx
w202 om606
323
01-09-2015, 03:17 AM #9
(01-09-2015, 01:33 AM)Eric78 Well this is an anomaly, The trans is definitely a WA580 722.636 but I've made a template of the bellhousing & the bolt holes all line up with my 605 which is an odd stroke of luck considering the 636 is supposed to be behind the M113
It's not possible, 722.636 has round bellhousing, if its says 722.636 on gearbox main body then I belive the bellhousing is swapped by someone.
722.636 on picture
[Image: 963426014.jpg]
This post was last modified: 01-09-2015, 03:18 AM by erx.
erx
722.636 on picture
Grecy
03-10-2015, 02:03 PM #10
(12-19-2014, 05:44 PM)Eric78
-Dan
Hey Eric78,
Can you please expand on how you can remove the bell housing from the main case?
Do you have any pictures of what the "bell housing" end of the split case looks like?
I know it's a bit strange, but I'm looking at the 6 speed box that's in my Jeep currently. It's actually an NSG370 (same as all the Merc 6 speeds) - so I'm wondering I can split the Jeep box in half, and put the bell housing end of a Merc NSG 370 onto the other half of the Jeep box - that way the shifter will be in the right place, and the output to the transfer case is easy.
Thanks,
-Dan
Grecy
-Dan
Hey Eric78,
Thanks,
-Dan
erx
w202 om606
323
03-10-2015, 05:55 PM #11
This bellhousing swapping is possible only with 722.6 NAG1 5 speed automatic boxes.
This post was last modified: 03-10-2015, 05:57 PM by erx.
erx
Grecy
03-11-2015, 05:33 PM #12
(03-10-2015, 05:55 PM)erx This bellhousing swapping is possible only with 722.6 NAG1 5 speed automatic boxes.
Ah, thanks, that makes sense.
I wonder if anyone has tried the "split case" approach I described above to essentially get the bell housing off the Merc 6 speeds.
-Dan
Grecy
-Dan
