STD Tuning Engine om606.. help!
om606.. help!
om606.. help!
edwinhoff
01-11-2015, 11:18 AM #1
i have a om606 engine, and was looking to modify it...
is has a mechanical fuel pump with electronic controll, what is possible to do with this pumpe or is it easer to change to a pumpwith mechanical controll?
what do you guys recomend to do for a light tune up?
hope to see some advice? Big Grin
edwinhoff
hooblah
01-11-2015, 11:22 AM #2
Electronic control is difficult to implement. You're better off finding a mechanical injector pump from an om603.
Install bigger elements. Larger turbo. Add an intercooler and suitably sized exhaust, and you will see a minimum of 300bhp.
hooblah
edwinhoff
01-11-2015, 11:34 AM #3
is it just to remove the old pump and install the new one. or do i need to change something else?
wow 300bhp and doing so little Big Grin
edwinhoff
01-12-2015, 10:24 AM #4
Swap the turbo actuator for a pressure one (stock is vacuum controlled from ECU).
Thats all to have it running fully mechanical, your power will be limited by the factory elements in the pump until you swap them as per hooblah's comment.
edwinhoff
01-23-2015, 05:53 AM #5
what Kind of turbo do you recommend for the setup?
edwinhoff
raidaru
01-23-2015, 06:09 AM #6
light tune up, meaning? 210 hp with a remap if u want, or 250 hp with remap and better turbo, like holset hx27 or he221w . More than this and u must go for the $$ way Big Grin
raidaru
edwinhoff
01-23-2015, 06:15 AM #7
i was thinking around 300-350hp what turbo then?
and i have bought a 7.5mm pump
This post was last modified: 01-23-2015, 06:16 AM by edwinhoff.
edwinhoff
raidaru
01-23-2015, 06:35 AM #8
(01-23-2015, 06:15 AM)edwinhoff i was thinking around 300-350hp what turbo then?
he221w is ok or hx30, is your pump electronic or mechanical? what transmission u use?
This post was last modified: 01-23-2015, 06:37 AM by raidaru.
raidaru
edwinhoff
01-26-2015, 02:57 AM #9
Its mechanical..Dont have transmission yet but I'm thinking of buying a bmw zf transmission
edwinhoff
 6 Guest(s)
 6 Guest(s)
