STD Tuning Drivetrain 717.411 information
717.411 information
717.411 information
PedroFerreira
01-07-2015, 06:57 PM #1
can this andle 240hp and 400nm? easy to instal in my om603 300d turbo?
what flywell can i use?
PedroFerreira
swampmonkey
hx40 super
280
01-08-2015, 08:13 AM #2
single mass flywheel, (take a picture of the box and i can help better if it realy is single)
and it could work, but it depends on how you drive it. i havent heard that the 411 is strong, but it "could" work.
as long as you dont upgrade the clutch, its probably the clutch that will be the problem and not a broken gearbox.
but i might be wrong Smile someone else might have better input Smile
This post was last modified: 01-08-2015, 08:20 AM by swampmonkey.
daily driver
w115 240d 72hp 3.07 rearend
+ a few more.
mbturbo.com
swampmonkey
daily driver
+ a few more.
mbturbo.com
01-08-2015, 11:01 AM #3
Want to say its rated for 85NM but my memory is old and flakey. I blew one up earlier this year.
PedroFerreira
01-08-2015, 12:20 PM #4
what material have to use do put a 6 speed gearbox? (w210 220cdi) what fly wheel?
PedroFerreira
swampmonkey
hx40 super
280
01-08-2015, 08:43 PM #5
6speed is dualmassflywheel, hansebanger still has his as a dualmass, so should work for your power Smile
daily driver
+ a few more.
mbturbo.com
swampmonkey
daily driver
+ a few more.
mbturbo.com
Stamsaas
01-15-2015, 09:55 AM #6
The 717.411 is "stronger" if you read on forums, but its not strong. Keep away from 3th gear and you will be ok. Or atleast be gentle with it, 3th is a quitter Smile
Box is to singlemass flywheel.
This post was last modified: 01-15-2015, 09:56 AM by Stamsaas.
Stamsaas
benzguy
01-15-2015, 11:04 PM #7
How about 717412 is that stronger or the same as the 717411
benzguy
raidaru
01-16-2015, 02:06 AM #8
(01-15-2015, 11:04 PM)benzguy How about 717412 is that stronger or the same as the 717411
or the 717.460 from w202 250TD engine?
raidaru
swampmonkey
hx40 super
280
01-16-2015, 10:16 PM #9
as far as ive heard, in terms of strenghtness.
weekest to strongest,
717.41*, 717.43*. 717.450, 717.401, 717.404
id guess the 717.460 is atleast the same as 717.43* gearboxes, or perhaps the 717.450,
the sixspeed 270CDI somewhat along the 717.404.
BMW,
5speed 525tds, 6speed 530tds and strongest 5speed 530tds ("way stronger than the sixspeed")
daily driver
+ a few more.
mbturbo.com
swampmonkey
BMW,
daily driver
+ a few more.
mbturbo.com
01-19-2015, 05:23 PM #10
(01-16-2015, 10:16 PM)swampmonkey as far as ive heard, in terms of strenghtness.
BMW,
C270 cdi uses a 616 gear box, 6 speed one the insights are nothing to do with the 717.
717 has a problem in the secodary shaft bearing, thats why the 3rd gear colapses. and the other is that to achieve smooth shifting MB uses the gears to slide against each other under TQ. something that is good for smoth shift, but under extreme TQ forces the gears against the bearings , resulting in execive play, prone to failure.
716 has completely diff engenering, i dont belive that any engine will be able to break it , unless it is abused. MB boxes dont hold direct shifting, it is a Conception problem.
fit a 616 , half fluid ATF half W90, clutch shifts all the time and u´re fine for a long time.
regards.
BMW,
regards.
Matej
02-18-2015, 10:15 PM #11
(01-16-2015, 10:16 PM)swampmonkey weekest to strongest,
Which of those can be used with a single-mass flywheel?
It would be great to know for sure.
Thank you.
Irony.cc
Matej
Thank you.
Irony.cc
benzguy
02-18-2015, 11:31 PM #12
You can use the 717411, 717412, 717404, 717401, 717430 with a single mass flywheel 717433, 717450 takes a dual mass flywheel
benzguy
soltysrsz
02-19-2015, 01:34 AM #13
hi,
How strong is 717,450?? Marcedes have made any adapter to suite dual mass gearbox to single mass flywheel??
Rafal
Mercedes W123 240D (om616->om606)
Audi A6 C4 2,8 Quattro (AAH)
EX Audi 80 Competition
EX Ford Scorpio 2,9 4x4
soltysrsz
hi,
Rafal
swampmonkey
hx40 super
280
02-25-2015, 06:43 PM #14
(02-19-2015, 01:34 AM)soltysrsz hi,
Rafal
got a "pal" that said his 603 was "benched" to about 350hp, and he broke his, and the second he got aswell.
but i have no idea how he drove them, welded diff, and pumping the clutch in third gear probably.
one of the "stronger" gearboxes, but also expensive.
Sprinter flywheel is the easiest i think, has the width of a dual mass but is a single mass flywheel
daily driver
+ a few more.
mbturbo.com
swampmonkey
Rafal
daily driver
+ a few more.
mbturbo.com
 10 Guest(s)
 10 Guest(s)
