Timing + Element change
Thank you to everyone for answering my questions so far, I have a couple more queries I'm afraid.
1. When fitting an OM603 mechanical pump to my OM606 engine how do I set the timing? Are there any good guides that I can work from?
2. If I was to get a local company to fit the upgraded elements to the pump what details will they need to know in order to calibrate it correctly? Is this information available somewhere?
Many thanks,
timing will depend on the retard notch on the elements, send the pump to Dieselmeken=job done
don't take this the wrong way, just a little advice.
i have pms from more people,( i have got some guy to fit elements, now he wants more money etc, pump is not working correctly etc,etc...)
they have spent the money they thought they were saving and still don't have a good pump.
(01-18-2015, 02:08 PM)LRDefender Thank you to everyone for answering my questions so far, I have a couple more queries I'm afraid.
Many thanks,
Many thanks,
I'm willing to agree with the guys above.
Have to ad one thing though What elements will you be using? In my opinion there are only stock Mercedes elements and Dieselmekens elements out there. The 7mm Transit elements are just crap and should never find there way in to any engine. Just not worth the money. I can almost put a dime on that Dieselmeken can make a better working IP with stock 6mm elements then most guys can do with some 7mm. Both in driveability and top end power.
Cheers
